battery panel mk2
Mk2 1984 Polo
Found some rust at rear corner of the battery tray and screwdriver probing opened a small hole.
Not bad after 26 years.
Filler and paint, or is it that area too structural for the weight of a battery.
Or new battery tray panel welding in?
And where to find a panel.
Beavers and Hadrian's only seem to do crash repair stuff like outer panels and bumpers for 81-90 Polo.
  • Views 2.6k
could fibre glass a small hole..clean it back to good steel both sides first
i don't think anywhere does a repair panel for the battery tray, just filling it with filler isn't good either.
To do it properly you need to cut the rust out, ideally cut it so its a square hole or something, but since it'll probably be awkward grind it all clean so theres no rust left.
Then cut the relevent size patch out of sheet steel of the relevent thickness, weld this in, grind back and paint.
The battery tray isn't really structural, but putting the battery in could nock a plug of filler out, it is vital that you remove/stop all rust to make it last. Atleast with a mk2 you can remove the drivers lower dash easily to get to the underside.
Tbh imo one small rust hole is excellent after 26 years :)
passenger's lower dash for me as it's a left hands drive (goofy not regular) so even easier!
Must have been using my SuperDry calculator.
2012 -1984 = 28 years
floor pan has had a few rust patches repaired for MOTs
and I've got a small rust patch below fuel tank filler pipe where the crud collected
(think that was preserved by leaking fuel from a breather hose for about 8 years)
but the wax inside cavities and steel quality is impressive.
Wonder whether battery acid had an effect. I recharged with battery in the vehicle this winter.
Edited by dvderlm
As said, it's best to grind off all the rust then weld a patch over the hole. Then cover it with primer. It's also a good idea to paint it with stone chip/underseal- you could either paint over this with body colour or mask up around it and cover the whole tray. it will then be a Matt black color and will look almost factory as Mercedes/BMW etc do this (and they don't rust). The battery trays rust because moisture collects under neath the battery and eats away at the little scratches the battery makes in the paintwork.of he paint is a little thinker/ harder wearing it wouldn't get scratched as easily.
HTH
MoT examiner's gonna grab your battery with both hands and try and tear it out, simulating pothole forces etc, at least if my tester's anything to go by. Any effort you put in will be vandalized unless it's welded steel.
best mention what size the hole is really , if its a pencil size then no way will a lump of fibre glass fall out or allow the battery to fall inside the car , if were talking a hole you can poke your hand through then yes it deffo needs welding
