15"x5 1/2", 4x100 set of 4 Mini One 7-hole alloys
This is a set of 15x5 1/2 7-hole Mini One alloys. The ET is 45 and centre bore is 56.1. If you want to fit them to mk. 2 Golfs, you'll need to very slightly largen the centre bore to 57.1 which is only a thickness of 1/2 mm all the way around. Should be pretty quick with a dremmel etc. They have no kerbing whatsoever as I have refurbed the edges myself. There is the odd tiny knick or scuff on them here and there, but I'm being fussy and as you can see from the pics, they don't show up and you'd only see them when looking really-close up! Basically they'll look great as they are as you can see! There are 2 tyres, but one is low on one side and the other would need changing in a few thousand miles. Other centre caps might fit or you could put VW symbol badges/stickers over the top (which are available on ebay)-see pics at bottom of mk.2 Golf with these alloys.
-£170. I'm in north Kent. Please PM me if interested.
Edited by Aquablue
Please allow 5 days before bumping.
  • Views 337
Now £150!
Ends on ebay tonight! :)
