i need a mk2 break fluid reservoir
i hav had a top strut brace put on my mk3 polo, but my brake fluid reservoir is blocking the brace from sitting down enuf, i need a mk2 brake fluid reservoir as apparently it sits lower and more foreward, and should clear the strut brace, pm plz iff u hav 1
  • Replies 10
  • Views 762
May have one. I'll check up the unit, going up in a bit
sweet bud
I think the outlets of the bottle are further apart on a Mk.2 bottle than a Mk.3 so it won't fit the Mk.3 master cylinder.
so how do peeps get a top strut brace on ??
citreon saxo resevior cap is the one you need but does not have a sensor
Edited by CHRIS2911
I have a mk2 reservoir, whole thing with reservoir if your interested
so do i need a mk2 reservoir or a citroen saxo cap wivout a sensor ?? is that an mot failure ?? dangerous in any way ?? an how much 4 the mk2 posted ?
how much do you want for it ? so will it fit ? what would happen iff i did not have a sensor on it ? mot failure ? :doubt:
Not sure if it will fit. Measure the distance of the outlets and I will on mine too
nothing it just lets youknow when your brake fluid is low and does not come into the mot
