1.3 throttle body to inlet manifold 'flange'
As above, looks similar to the mk2 one where it bolts onto the inlet with nuts underneath and then the throttle body bolts to it with the four allen key bolts. its not just the square block that you get on the lL engine
If someone has one they can send me by the end of the week then i can hopefully finish Fern before Stanford Hall this weekend
thanks a lot
Liz
  • Replies 8
  • Views 494
I'll have a look tonight - think I may have one.
thanks, just to confirm i need the one that fits an AAV 1.3 mk3 engine throttle body to the inlet manifold, it should look very similar to a mk2 one where there are bolts further out that go through the inlet and it bolts on with nuts underneath, then the throttle body is held on with 4 bolts. a Mk2 one will only have 3 bolt holes
thanks
Aye, I think I know the type you mean - hopefully it's still around and the right type. I'll get a pic up later.
Any good?
thats the chap! i think randombadger may have one for me he was going to let me know today if he can get it in the post, if not I'll give you the nod soon as - i need it to arrive by Friday latest
thanks!
Sure. I've brought it with me to work today so can pop it in the post at lunch if you need it.
Two flanges are better than one ;)
ok thanks a lot, probably best do that if you don't mind! I'll Pm you my address now :-)
let me know what i owe you!
