happiest day of my life,
just about finished my megasquirt and itb install on my gt today, its no where near finished yet but i have finally managed to get the dizy to trigger the ecu and a spark and it even tried to start when i cranked it over! hopefully il be able to attack the strip when bug jam rolls around!
just thought id share my happiness with everyone!
Also is any one else running megasquirt on a polo?
Edited by ash_gt
  • Replies 27
  • Views 1.9k
Fantastic.
Thought about it a few times when the carb ws doing my head in.
You using Hall sender or 36-1 wheel?
I know the feeling, when i first got bike carbs to fire up on the 1.6 AEE it roared into life with an ear-splitting howl, i pissed myself laughing as i felt exposed and almost naughty, imagining pets running for cover and wondering how people must be thinking 'wtf is that!?'
Hi mikey *waves*
Cool story, Bro
Thanks prety happy to say the least, I have finally managed to get a trigger from the hall in the dissy but as it isn't a very well documented sensor it took a little thought!
Also tried it today and it even starts! Running extremely rich but hopefully shouldn't take much playing with the map to get it running right good day!
This thread needs pics! Or videos will suffice ;)
Nice one though dude, good effort!
When I manage to get it to roughly idle I get a vid up for you!
Well done mate, nothing more rewarding than the first time something springs to life!
I intend on using the hall sensor instead of a 36 trigger wheel, the standard ECU manages it with the hall sensor fine eh?
I plan an install and getting it running roughly within a weekend haha :)
What inputs have you given your ECU?
I was gonna use hall sensor (angle & rpm) coolant temp, air temp, TPS.
Use a wide band AFR for tuning..although a lambda input maybe good for calibration factors?
As long as I can have it set at a decent cruise (15.5:1 ish) on low % load and TPS be ok, then at higher throttle it will back timing off and give it more fuel be fine!
Just a fuck about calibrating all your sensors and such! Well TPS is easy, like the hall sensor/temp sensors
surely if your Wideband AFR has either a Wide or Narrowband Output there would be no harm using it to control the fuelling with ITB's.
It has a single wire haha I dunno!
I'm excited to read more about this and stuff though!
Keep up the work!
Well done mate, as already said that first time some thing fires into life is such a buzz 8-)
this was a happy day
BecauseRaceCar
haha lol
well i have got it to idle rpm is a little high not too bad tho!
revving verry freely which is WIN!
not as rich which is also WIN!
a video is currently uploading to you tube of the second start today!
so currently i am winning!
Il post a link to the vid when it eventually loads!
as your thinking about microsquirt i would also go for a map sensor as you can then take advantage of the speed density/ alpha N load sensing in the tuning software!
Itb's and MAP? How would I do that?
Would I need balance pipes between the inlet tracts or something?
I just want to map fuelling for performance at high throttle %age and cruising at low %age, with a startup map etc lol.
Like me! A vac take off on each body after the the buterfly take those to a couple of t pieces then in turn to another to give one vac feed then through a bike fuel filter to dampen signal slightly then to the map!
Hi mikey *waves*
Male TT driver waves at you.
what do? :paranoid:
*subtly nods*
Had a pic of some cars at a show - you, mrs and baby were sitting on the grass behind the cars in the sunshine, i've tried to find it for you but can't find it anywhere at the moment. Think one of the cars was your old 6n2. If it still exists i'll find it and send it to you.
Manifold already has 4x tapins :p
Crikey you post back quick! But yeah that's good some would say its no good but it depends on the signal you get if the guage on the tunerstudio is pulsating like a rat on crack its probly going to mess your fuleing and timing but mine so far seems good, but now I have to make a throttle cable so I can script see if it drives!
I'm not convinced by MAP tbh but we shall see, I need to read up on EFI & ITBs generally!
Be good to follow progress of this though mate
You and so many people don't tbh! BUT using map for what load sensing seems to be a good idea to me when the map gives a rediculas signal its at idle and low throttle but when it gets into the higher revs the ecu has a much more acurate waY of predicting the load than just tps but the tps is still used in the low revs, probably the worst explanation ever but its late lol!
Hmm dunno, I dunno what to do about cars haha. Might just fit bodies with standard management and up the fuel pressure aha
Do it! I have wanted to do that but didn't dare, you could use the original sensors and just impliment them in a different way and as you said up the pressure and hope the ego corrects the mixture I'd be intrested in the results!
