Door Pillar Stickers
  • Views 857
Yup :)
Our own Dknight. They're a good item, and fit very well, but can be a bit tricky to fit as they're designed to be stretched on to get the right finish.
I need to redo mine as theyve split and look horrid but looks as though theyve been replaced in the past! Would have to get the heatgun out and heat the old ones off.
yeah word of advice pick a sunny day and leave your car in the sun for a good few hours, it makes it a million times easier softens the glue and helps the vinyl not rip, or just boil a kettle and pour over before.
The vinyl is funny stuff, as it shrinks as soon as it is cut, so if you have old decals unfitted they naturally just shrink. But when fitting them you can easily make up 3-6 cm if you are careful.
I find just line them up from the top and see where the bottom sits, they will always be slightly smaller, if we did them to actual size and you fit them there is always stretch, and once stretched over size there is nothing you can do.
For the sake of popping your rear windows out aswell you will save alot of time and get a much better finish
