Rust on Sill -Quick Fix?
There is only really one area of rust on my Mrs' 1998 Polo -on the rear of the N/S sill. The back of the sill has rusted off completely.
The MoT man failed it, but really everything else that is wrong with the car can be done easily. I just don't have the means to weld the sill myself at the moment. Most of my local garages don't do welding, and the modbile welders charge a fortune.
Is there something I can do to get it through this years MoT, and then weld it up myself in a few months time when I have the means?
I know that you used to be able to make/fit plastic sill covers, and then the MoT testers can't fail on the condition of the sills under the covers, as they are not allowed to remove them. Is this still the case?
Were any Polo variants fitted with plastic side skirts/sill covers? Would they cover this area?
Cheers guys!
  • Views 3.7k
it realy does want to be welded up, although you will get some pikeys on here telling you to simply fiberglass it up. but seriously it does want welding up right, if your just having a patch put on then souldnt take more than a mornings work
well if you did fibre glass it it would need to be strong and invisible to the mot man , if he gets a hint theres a lump of fibre glass he will do his best to bust it off with the poking tool they use
for the cost and effort of bodging it up you might as well have it welded up now...are you sure the rest of the car is sound?
The MoT tester didn't pick up on any other rust on the car, I knew that bit felt a bit soft, but the MoT tester dug it out to what you see in the photo.
if you can weld, just bung a plate on there and spray it up lol, if not, 6n's come up really cheap sometimes anyway. may just be easier getting another one :lol: plus you get the new car feeling haha
