Pow-Low................
I thought I would stick some pics up this time so you can all have a laugh ;D
I'm combining Juice and Air so I'll be using juice for the lift and Air for ride/comfort control no other reason than why not and I had most of the bits laid about...........
First off get the plasma cutter out.
And weld them up
Thought I'd have a go at TIG whilst I'm on.
Take one of these,
And chuck em all together,
Bit of tube and a ram.
Drop the ram inside the tube and cut the bottom of the strut off weld them together and.
The rear is similar only rose jointed at the bottom.
There you go chaps still plenty to do..
Edited by Mk2 olop
  • Replies 16
  • Views 1.3k
Cool story bro
(did you forget to attach pictures?)
No for some reason only four are showing up.
How many can you see??
Mods??
15 pictures for me.
I cant see em does it make sence Matt?? :-(
oh myyy you nutter! MOARRRR :lol:
Me too :)
Looks good anyway.
I can see more now, but couldn't see anything before
So are you using the air bags in the place of an accumulator?
And is this all going to fit in a polo? My boot was filled with shit when I had mine fitted and that was just a basic hydro setup with a couple of accumulators and a single battery :lol:
Mclovin,
its a breadvan with no back seat so plenty room.. :D
Poloman,
The tash thing is just a frame to house the air springs which are being used instead of accumulators not decided yet were its going but it may go under the dash yet..........
Are you having 4 bags, one for each ram? And are you also going to run a compressor and tank for the air bags or just charge them to a chosen psi as you would with an accumulator? Also is that tash thing going to fit under the dash? It looks fairly big in the photos :lol:
This seems like a hell of a lot of extra work for some thing that will give no gains over an accumulator setup other than to say its got both air and juice, that said I do look forward to seeing how it turns out, its nice to see some of that 'because I can' attitude being used. Maybe its just me being a bit of a pussy but I wouldn't feel safe using a strut that's been so heavily chopped about as the one you've made, but then you've probably got a lot more faith in your fabricating than I have in mine tho :lol:
Loon! :-D
Used on the road?
What have you used as a filler material when welding the "strut" there and how have you heat treated the parts? Highly cyclical loadings on a critical part - really not something that you want to be welding... :paranoid:
Loon! :-D
Used on the road?
Don't worry Speedview its plenty strong enough and I'm gona add some fillets and some plate to A, make it more pretty and B, spread the stress.
when do you think we will see this bouncin then? lol
Well I have just been made redundant so probably sooner than I thought!! :biggrin:
Could do with a role cage and front sub-frame if anyone can help????????????????????
I think theres someone on here that can get you a cage? Have a look in the traders section
