What to look for when buying a mk3
Hi.
I'm going to look at a mk3 1.3 SPI tomorrow.
Had a crash tonight, I'm fucked, not in the mood for searching and such, need to get a car sorted for work.
What should I look for?
  • Replies 31
  • Views 1.8k
Battery tray , check under license plate on boot .. normall things when viewing any car tbf
Check that its not a bread van
^^^^^^ hahaha
Thanks saf.
I'll rip interior out and trims off tonorrow ha
Just seen a Bready with 6k on the clock on the bay at 1700 what the fuck
Suck my jewish-esq dick :lol:
It's not a bread van anyway. Bread gives me hiccups
bready's are good for carbs ....
hahaha see what i did there hahaha or not :doubt: lol
hmm!
bellend :lol:
X2 bready ftw! Hes just jelous as hes got the round arch generic model :nod:
x3 on the jewish-esq dick!
Its usally quite obvious if its a shitter nick. Just check everywhere!
How do I check for rust behind trims when they're attached lol
Could use as a work slut anyway and buy a G Too
Edited by harris.racing
give them a little shake .. see if they feel solid .. If the trim comes off with rust from the body , \
walk away :haha :grin:
If I put a vacuum cleaner near it and it disappears..walk away?
the arch trims only cover the outside, just pop your hand behind the arch and run it across, it you get cut and end up with tetanus, you know its rusty! where is it located? maybe get someone off here to come and have a look with you
not entirely true, some can you quite good, or look like they have a mild rust spot underneath flaking underseal, but when you start stripping it back, it can be a right old mess!
mind you its all easily sorted with your obvious motivation nickolas mcpaedofeatures
Buy buying a breadvan; no trims to worry about.
Dont buy anything with arch trims. They suck balls. If they're factory, the arches are normally rotten under them. And some people fit them to hide rust, which then gets worse, as water/ salt/ dirt sits underneath and munchs away at the metal. I hate arch trims, can you tell? :lol: Front jacking points are a good place to look, as they can be damaged by the jack, and rust quite badly, which can move up into the floor. they're old cars, so rust can be pretty much anywhere.
And, sometimes you cant tell if its a shitter. Dont be blinded by shiny paint and low mileage. It can still have its bad bits, or be a bodged up rot box with fresh paint. I advise taking a strong magnet, as if you run it over the body, you can feel the strength of the pull from it change as you go over an area of filler.
But then your stuck with a breadvan, I'd rather take the chance on a rusty coupe tbh. Arches can be replaced, pride can't
Another way to check the arches is to give them a little pull applying pressure progressively, not only should they not have any give in them but listen out for the sound of a hand full of corn flakes being crushed. If you hear that its not a good sign
This thread was suppossed to be about MK3's, so most of them dont have arches. So just avoid GT's, or lower spec models that have had arches added.
Look at the post above yours, that's what I was replying too :wink:
But there is no reason what so ever to be scared of trims as long as you know what your looking for. I have seen trims hiding some right scary shit but I've also seen them with perfect arches underneath. You have more senses than just the sense of sight, arch trims just mean you have to use some of the others to know what's behind them :thumbsup:
Edited by Mclovin
Does it have a turbo?
Does it have boost?
Fixed for you :thumbsup:
Does it have boost?
Does it have boost nick!? DOES IT HAVE BOOOOOST!!!!111!1
:thumbsup:
Edited by mattpolo5491
