What to look for when buying a mk3
It's a cl with trims woop! BYE
  • Replies 31
  • Views 1.8k
Harris don't believe the hype. People have actually been known to fit arch trims because they like how they look rather than to hide rust :lol: go have a look at it and see what you think. Poke and prod it as much as you can, rust can be hidden from sight but not from a good hard poke :lol:
I'm guessing its fairly local? If so what have you got to loose from looking at it? If nothing else even if it turns out to be a pear you will get an idea of where you should be looking on any others you go and view :thumbsup:
just read the post from malaga red regarding running a magnet across the bodywork. i would kick someone in the chops if they ran a magnet across the paintwork of a car i was selling and tell them to jog on!
Check that its not a bread van
I'm with this tbh!
Depends whether they're dragging it across the paint, or just using it to check for bog.
Haha!
Well I'm sure you're aware I bought it.
Looks pretty solid tbh, probably better than my 6n (awaits guys comments) but yeah.
Took more notice to seeing things that suggest some people just shouldn't modify cars realy! :)
But hey it starts and goes!
Also the magnet thing, you don't hold it on the paint, if you run it along a pannel at an equal distance you feel it's "pull" change due to varied thickness to the metal below paint/filler.
You could use a paint depth gauge really, but my neighbour wasn't around to lend me his!
Do these just have 2 stage paint instead of 3? Ie primer and paint which is glossy instead of primer paint lacquer?
