Getting locks out of door handles 6n
As above, is there an easy way of doing this? Want to paint them and would prefer to remove the lock completely.
  • Views 736
Have you got the handles off the door?, if not then it's a torx bolt behind the handle in the door shit. Undo the bolt then slide the handle towards the front of the car and pull out.
When they are off you can remove the spring clip from the handle part (or seperate the whole handle fronts lock of you have a small punch)
As for the lock barrel itself there are two types on the 6n, a nearly type and a later type if you have a flat key then it's the newer type and if your key is the sharp sides older style then it's a lot easier to remove the barrel. On the back of the barrel you will see a paddle follow the shaft down and you will see a spring over the paddle and the paddle will have a hook at the bottom. You have to push the paddle down and unhook it. Then put the key in and turn it 90 degrees and pull out the barrel. There are a few bits in ther so remember the order they are in. It's a good time to clean them all up and regressed before you put it back together.
For the later style lock it's a little more complex and needs a few tries to get it back together.
If you look on YouTube for vw lock there are a few tutorials on how they go together.
If you are stuck on anything then just post it up on here.
-also when the handle is off te car it is still difficult to unlock it so dont worry too much about someone breaking in.
HTH
Yeah they're a bit of a pain and you need the key, incase you've bought another set to use to paint
Yeah its the later type, will have a go later and post if I get stuck! Have the key, I bought a cheap set to put on whilst I'm painting mine.
