help on fitting new front springs for my 91 gt coupe
got some new springs i need fitting on my 91 gt polo coupe can do the job myself but have no sping clamps compressors , anyone around my that can help ? m42 j5 solihull west mids
  • Replies 51
  • Views 2.7k
corr what a job, just done this on saturday. not close enough to help really, but you will need spring compressors. the rears you can do without, and use the weight of the car, but youll struggle without a compressor on the fronts.
and i couldn't find any other way to get to it without disconnecting the whole front leg from its driveshaft, brake calliper, etc etc. oh and theres a funny little circular nut-like bit that's a bitch to get off.
Good luck, someone will help I'm sure
done the rears no prob in and out in two hours :D and i know the front is a bitch from what i have heard other people say , thanks anyway bud
Bud I am from Solihull, Erm but i Don't have any spring compressors :( Surely you can get a set for round £30-60. Shirley auto spares?
i had a look at the ones in halfords and thay look nasty and cheap and do not want to loose any fingers :-(
i used my uncles, they cost him 25 quid off ebay, worked a treat
Erm well you could buy the 1's from halfords and use a ratchet strap to make sure, You defo wont loose fingures then. We have 1 at work that is shocking, We put a F430 front coilover in it and it decided to jump out and land on the floor LOL. But hand held 1's are the way forward.
thats what I'm worried about not sure what to buy ? and spend shame really as only going to use them once
how low are you going?
Take the shockers off complete and take into a garage with your new springs.
They'll charge but at least you won't have a spring embedded in your forehead and you won't be left with a tool you won't need
I've just realised, you're only doing the fronts so you dont actually need one if i remember correctly, one time youd need one is disassembling but if you have a vice or something to stop it pinging at 100mph you'd probably get away without one.
tbh mate, if i were you, id see how far you can get and at worst if you need to go get some from halfords. but at the end of the day, if you can do it without then its 30 quid saved
not that low think its a 40 drop
got a big vice but not sure i got the balls to do it that way :paranoid:
You could do it the barry boys way, Leave the shock on the car, and take the top mount off whilst running away and boom, but i would rather use them £30 1's tho
yes but do not want to get ripped off
Erm well you could give it to a garage? But you could end up paying more. These will do the job perfect mate!
http://www.halfords.com/webapp/wcs/stores/...tegoryId_255216
well thay are the ones i was going to buy buy my mates dad had them and thay slipped off the spring when he used them and he not got them any more
Hi mate i will try them and see what thay cost thanks
you guys make it out to be absolutely lethal. :lol: just make sure you face away from the spring and take care, honestly, dont worry so much, give it a shot or spend the 30 quid up to you buddy
but tbh, the garage will probably charge you less than the cost of spring compressors if you walked in there with everything you need, cant imagine they'd charge 30 quid to swap some springs on already removed shocks. i'd do it for nothing if i was a mechanic (probably a good thing I'm not, or id be broke :lol:)
still not sure but will have a go .. while i do the job should i replace any other parts ? as i kinda want to do it once and do it correct
i did my brake pads too so check them... erm, the rest depends on the condition of your bushes etc, might want some bump stops too on a standard shock, but thats up to you.
was thinking top shock mounts ? but again not sure what ones and who from ?
