show us your pics of your rolled arches on a 6n
Gonna be doing mine..but looks like people use different methods thanks
  • Views 1.8k
did mine with an arch roller, did it abit more than i would have liked, got abit carried away :p got no flaking paint either just used a heat gun to heat them up. I would personally say roll them until the flat edge of the arch is just starting to flare out, dont go as far as me so the flat edge just matches into the wing
Cheers for the info mate
This looks cool! If you dont have an arch roller you can bodge it with a widow maker jak (the one you get in car with your spare wheel)
put and axle stand under your axle (durrr) and then place the smaller end of the jak on something solid (i used my drums as i ahve only done the back) then use a heat gun on the metal and slowly crank the jack up evenly moving the jack from the back too the front of the arch is even sections. (best overlapping the points you have put the jak on to make the arch smoothe.
warning tho it can chip the paint on the edge of your arch but it better then having your tyres running along them constantly?
Saunders
Use a hammer.
Saunders
have you tried this? :) would like to see pics of it if you have any? :) :)
Show us your pics of your rolled arches on a 6n, also how you did it?
Well, i was going round this corner right, and..
