tt rear bench
do mk1 audi tt rear seats fit in a 6n?
  • Views 928
They have only two seats ;/
so you will loose seating in your car otherwise i believe they are pretty much the same size, may have to swap base but I'm not tottally sure.
Saunders
above is wrong, they are not the same size and a very large amount narrower- they also hinge in a completely different way, the seated part has no base and is just a piece of foam - leather clad.
They do fit in a 6X though ;)
they fit in a mk2f if you have the time and skills to do it.
