my new mid-life crisis micro tractor
hi everyone :) I've been a lurker on here for many years
I've always owned Lupos, I started with a 1.0l, moved to 1.4sport but got bored and craved power so bought a GTi about 6 years ago. some peeps may recognise her
258_51353485620_508205620_3348375_909_n.
after many years of being a work horse she deserves some pamper time so I've retired her from being my daily to smarten her up for next season. I've also got a new job meaning ill be driving 120miles a day so the perfect solution, the bluemotion :) picked him up yesterday and hes taking some time to get used to I'm so used to powerful petrols, I'm constantly in the wrong gear!! but I'm getting fond of him already :)
75247_10151683786775621_508205620_241448
i have just one *crucial* question, does lowering affect MPG?
thanks
Jen
  • Replies 11
Nice Lupo!
Lowering will not make thes lightest difference to your MPG.
Unless, of course, you drive your car differently.
Give me Grille!... worth a try right :p
^^this is exactly the right answer i wanted to hear woop!! i forgot i was driving him today and slammed on my brakes at a speed bump but then didnt even feel it under his balloon tyres :) bless
It will help MPG, you will drive slower in bumpy areas and you wont have to brake as much for corners so you can carry more speed out of the corner with less acceleration.
not to mention increased aerodynamic efficiency.
however, constantly slowing down then speeding back up because of pot holes/speed bumps etc will have obvious effects on your mpg.
Swings and roundabouts.
doing 120 miles a day I would assume means motorway driving where you shouldn't be slowing down and starting again unless its the M25.
yeah, be reet on the motorway. just around the average road in this shithole.. not so great haha
roads that bad in the midlands? been to brum but literally to the NEC and thats it. poor roads down here but still acceptable
I struggle to do 20mph on the roads on my estate.
infact, most the roads around here i have to go slower on because they are disgusting
i was even thinking 'everyone on cp bitches about the roads being bad by them' they should genuinely try driving around here :lol:
Go across to stafford and they are instantly better :lol: :lol:
Lowering my car has usually destroyed my MPG. It ain't rocket science either..
Springs were not the main issue - It was generally figety and bouncy with uprated dampers, and that wasted energy needs fuel. Add to that a less fluid and less consistent journey, a less consistent average speed, longer journey time, and it's not hard to see where (and in how many ways) the efficiency was wiped out.
So i then kept to a max of 40mm springs on the soft factory spec dampers, keeping a supple ride quality and ability to take minor surface changes with relatively little corrective action. Basically, a supple ride makes for a more consistent and fluid transfer from A2B. This kept economy up (and, in hand, journey times down so you get to your destination quicker as well as cheaper).
A hopeful counter act was to be able to take corners etc faster, but that doesn't happen in reality unless you're driving like a prat.
In my experience, fitting harder, lower suspension is like walking off the footpath and walking across rubble instead. It's less efficient.
Btw - Lupo GTi is a very special motor 8-) As it's lowered, don't you already have your own findings on this subject..?
