Arch Linings with Rolled arches..
Hey all..
As the title says, Iwant to put my arch linings back on the front of my 6n.. I've have the front arches rolled (but not flared) so when i put the arch linings back onto the car, it hangs slightly lower than the arch line and looks crap.
Anyone got any ideas of how i can keep the lining above the arch line out of view? Usually there is a lip where it would sit but obiously its been rolled..
Its probably a shite question with a simple solution but I'm stumped atm haha
Aaron
  • Views 816
Either cut them out like I already said.
Or I just had another idea. Try unscrewing the whole liner, then moving it up to just above the arch where you wont see it anymore if you understand?
Then make new holes in the liner to screw it in to where it was originally mounted?
Hope that makes sense.
Cut about 15/20mm off the edge of the liner.
I just bent the tabs where the screws go through.
Screwed in standard place, apart from bolts on arch lip removed and held in the the metal tabs bent up.
No cutting, holds it up out the way
