how do i remove my headlights on a 6n2 ?
Anyone got any idea on how to remove my headlights on my 6n2 ? is it a bumper off job ? also if therea any step by step guide that would be good. cheers
  • Views 5k
this is a safe way around it yes and it gets the job done but it looks very long..
Undo the bolts ontop of the headlight and the top of the bumper (so the bumper has a bit of flex)
take the indicators out shown in the blog post..
if you have nimble fingers you can take the bottom grills out of the bummper at the bottom and reach up and undo the two bolts and the bottom of the headlights.
then the flex of the bumper comes into play.. normally helps if you have someone to lend a hand
pull the top of the bumper back about an inch just so the headlight has a bit of movement then with a bit of force you can pull it out..
putting it back in is always fun but can be done without having to take the bumper off.. just thought id let you know if you dont want to have top remove your front bumper.
Saunders
