project who knows
Good to see abit of nice welding in a project like this mate, good to see you redesigned that mount too. Looks much nicer/stronger now :D
Good luck :D:thumbsup:
  • Replies 46
  • Views 7.5k
  • Thought I would bump this back up works been a bit slow with it recently but things are getting there now Engine bay is all smoothed and painted and currently making new brake lines Engine has gon
Nice work good to see you getting there, i like the remix on the mounts
Cheers its getting there very slowly
Cheers had all the mount tig welded so the welds looks amazing plus the mount looks more like it should be there
Yea the new mount should be alot stonger as all the weight is pulling down on a strong part of the leg and not hanging off the end like before
This is gnarly! keeping my eyes on this one :thumbsup:
fair play to you mate, think this is one to watch
Cheers hopfully have a bit more of an update after the weekend
nice work mate, loving the new bracing :thumbsup:
cheers mate should be somthing different as you carnt really do it if your using the stock 6n engine mount on the drivers side
Fantastic effort Chris, really nice to see you getting somewhere with this now! :)
  • 3 months later...
well haven't updated this for a while but i have been working away finishing bit and bobs up in between re spraying my passat
first up managed to get a hydrolics pedal box of a fellow CP member which i modded to take the a throttle cable pedal instead of DBW
next up i had to mod the bulk head to take the clutch master cylinder, i have seen a some people just wack a big hole to allow it through but i wanted to do something a bit nicer looking so that you could almost miss it is on hydrolic clutch
didnt get any pictures of the makeing of this but basicly i cut the bulk head to allow the master cylinder to come into the engine bay then fenched it in with to holes for fluid in and out
managed to get it to blend quite nicely into the bulk head so it lookes very factory IMO
i also got a motorbike resivoir to use (not sure its goign to be big enough but i hope it will work)
with that pritty much finished i was next onto the passenger side engine mount which is pritty much finished now has been the hardest part so far on the conversion but iam happy how its looking (more pictures to come once its finished completly)
now once i was able to hang the engine by its self with out the craine i needed to make sure everything fitted. i have had the front end on previously but never re fitted the bonnet scince i started the conversion. i was pritty confident it would fit but had to make sure so i completly bulit the front of the car to find out, was very happy to find out it did all fit
thanks for looking hopfully some more updates soon
chris
and heres a cheaky pic of the passat with its fresh coat of paint
good work on both cars. i know the joys of too many projects lol.
i assume the clutch cylinder is removable incase of failure?
yea tell me about it keeps me out of trouble tho
yep altho it will most likly need the pedal box out to change it
Good work as always Chris, look forward to the next update
looking good carnt wait for an update
Ah only just had a proper look at this, awesome progress mate, nice to actually see someone doing what they set out to - work looks top notch too which is refreshing :) love some good workmanship
  • 9 months later...
Engine has gone to the builders for some work
LSD has been ordered then the box can go off for a freshen up
All suspention should be off to the power coaters in a week or two
No pictures ATM but they will follow
Nice one Chris, Nice to hear your still going at it!
Wish I had the time effort and know how to do something like this. Keep up the good work
Awesome work as always Chris :smile:
  • 4 months later...
Well it's been a while from the last time I updated this but work has been done although slower than I would hope but it getting there
First off the bay is painted and all new brake lines have been made and some bits painted
8fbac297996580be0c9b1b3ecc5c43e2_zps578d
8d607e3f11b6826e4858909a31da75e2_zpsab0b
581e70f1f2c38922acda1924f0febdf9_zps8c99
a839b6da9833e87f4b5c60f655db7dce_zps0c5f
I have also started to polish up the body work
a6731e72c7358c9e30e66d9a575cffcc_zps9697
4b46aa929d4cfdbeb0bef4bf887e244e_zps8488
a690a3cb9b2a09def97fe817b56af68d_zps939f
Next I manged to get a non pas steering rack so I could delete the pas system and also got the seem welded frame and wish bones back for the powder coaters and fitted up with powerflex bushes all round
07f819c8df239eb9649746337cfe2095_zps0b5b
I also managed to win a large core alloy rad for a mk3 golf gti on eBay for £44 I set about making it se in the space available in the polos front end it took quite a bit of chopping and will need some custom brackets but it fits and also sit a lot further forward to clear space for the oil filter on the abf engine. There is also room for the oil cooler. And it also leaves a big hole at the top to feed the throttle bodies
b70d0f093d934bfa8491e3d545e122b8_zpsc1ba
That's it for the minute I have some more bits ready for the powder coaters and the engine is currently been rebuilt so hopefully some updates soon
loving this colour dude, always had a thing for this dark green :thumbsup:
if you have any probs with the mk3 radiator when you come to plumb it all in the mk2 16v gti has a slightly smaller radiator but is a twin core and fits very nicely
