Mk3 heater!
Hey peeps,
Got a bit of a problem with my heater!! It all appears to be working fine
Except that when stationary the heater goes cold even when the engine is up to temp and even sitting in traffic when the temp goes up a bit more!!
As soon as I start moving it warms back up and goes back to normal
But as soon as I stop again it goes cold!!
Any ideas what this could be??
Rich
Without checking id guess your water pump has seen better days.
If its one with plastic fins then they have a habit of snapping off, If it looks really old then it might have a metal one and these rust away till they become ineffective.
Ok thanks allot for the reply!!
Is there anything else it could be or is it almost certainly water pump??
Are 1.0ltr water pumps the same as gt ones? Only because I put a brand new one
In my 1.0ltr engine about 4 months before I put the gt lump in!
Thanks again!
Rich
They should all be the same on these engines, the plastic impeller fans are a waste of time in my opinion, but obviously the failure rate of the metal ones was too low for people to make money on. :lol:
Sweet I'm pretty sure the one I fitted to the 1ltr had metal fins!!
Will go get it out the garage tonight and chuck that one in then I reckon!!
Thanks for the help!
Rich
Right have changed the water pump and it's still doing it!
Blows warm until you stop then after about 30 seconds at idle it goes cold but if you
Take the revs up to 1500 it gets warm again!
Any ideas ??
Rich
any other symptons .. This happended when my headgasket was on the way out :/
.. Try giving it a good bleed again .. Can sometimes have a leak in your system causing airlocks...
I'm not sure how correct i am but i heard that the water pumps are really bad at reasealing once they have been used already, dont know if this has anything to do with your problem as you swapped the one over from the mk3.
