I wanna move my number plate :)
I have a 6n2 and wanna move my number plate to the grill below it, just wonderd how do I get it to stay there? Any help would be very greatfull :)
  • Replies 8
  • Views 2.1k
I was thinking this lol! But how do I remove the lower grill to zip tie my number plate to it?
Why would you need to remove it?
Needle nose pliers will help you feed the cable ties through.
Might have to give that a blast then never though of that, and just drill some holes in the reg plate for the zip ties
Or just loop the ties around the plate? Also, the bottom grill just tugs out.
I was gonna suggest making a pair of brackets, fitting them to the inside of the bumper behind the grille, then passing fixings (thread through tube) through the grille to fix the plate solidly and securely in front of the grille so it's safe and legally secure.
But that'd be silly.
Cable ties are the one!
just drill 2 holes in your number plate each side and then feed them threw the grill, as when you remove the grill there is a high risk of loosing multiple clips as i found out as i previously did this and fastned my plate to the grill with nuts and bolts (far too much effort dont bother trying this) and then having only 5 out of the 10 clips left on the grill i lost the whole thing when being a dick and ragging my car around one night :L Awkward moment when you wake up to see parts of your car missing from the night before..
