MK3 polo help
Hi guys, I crashed my car a few years ago and have been looking for parts in the right colour ever since (around 4 or 5 years ago!..). I've decided to just go for some second hand parts in any colour and get them sprayed in the right colour (Calypso green). Its my first car and had it since it had 6k on the clock (brilliant find!) and currently only has 60k (still in good condition besides for the body work). I wont ever end up selling it so I'm going to use it as a project.
I'm just wondering if anyone could give me a quote 'guide' on what I might expect to pay to spray paint a drivers side door and driver side front wing in the right colour from parts off another car. Its even been suggested that a collage might be able to do the job, as I'm a bit tight for cash at the moment.
The rear quarter also has some damage so could someone advise me on whether that damage could be dealt with well (so its unnoticeable)?
Some of the trim was smashed off when the car was crashed too (you can see in the photo) and I'm wondering on how I would go about getting hold of the trim again and how to re apply it to the car? My aim is to gradually upgrade the car to a GT so I'm looking at getting hold of some wheel arches at some point (and other parts too), so could someone advise on how the wheel arches are fitted also?
Here's the damage to the car;
Any advice would be hugely appreciated!! =)
Nick
  • Views 1k
Wheel trims, Your best bet is to get a body shop to give you quotes, but the rear quarter could possibly be pulled out by a dent person.
Front wing and well for a door then just look around on here.
Hope this helped
Liam
that would cost around 400-500 to spray and pull the dent out off the rear quarter.
for a new door allow yourself upto 50
the wing you should pick up for around 40
your best be is to fine a local breakers yard and head on over there :biggrin:
The bumpstrips are only held on with what i reckons tigerseal. You can pick that up from hardware shops or somewhere like B&Q.
The arches are held on with little plastic rivets. there should be small holes in the lips of your arches to facilitate this and the rivets are easily available from ebay for around £4 for 20 or so.
As a rough guide, based on paint and labour costs at my place, I'd say £500 to repair the quarter and paint a replacement door and wing (with you supplying the parts, and you stripping and fitting up the car before and after repair).
The biggest charge at any body shop is labour. We charge typically around £30 an hour, so factoring in a few hours for removing panels and refitting which its easy enough for yourself to do with the right tools, plus the labour of the repair and paintwork can amount to a small fortune.
Its all easy to replace, the quarter being the exception. As for refitting bump strips. We use some foam refix tape at work. You should be able to get it from bodyshop supply shops or a search on ebay.
