Harris' Mk2f CL Coupe
Hey...
As most know, my 6n is now written off, and everyone raves about earlier polo's, so I bought this the day after I crashed in a bit of a rush, but its pretty solid, few little bits of rust..but its a good base to build upon :)
Spec is pretty standard atm..
Alpine White
GT/G40 arch trims and strips
G40 RA's
Clear indicators
Smoked side repeaters
Lowered 60/60ish on some PhilJ budget TA technix shit suspension stuff ;)
Genesis seats
Genesis or GT clocks..I dunno, has a rev counter anyway!
So it has a few niggly bits I'm sorting out, and have also treated it to some new bits :)
Basically I didnt want to buy a modded car, as I know of so many accounts of people who just shouldnt work on cars, modding their own..but anyway.
Needs:
Passenger mirror glass
Fuel pump whining Cleaned it out and has fixed itself
Backbox broken Replaced
Rear top mounts assembled wrongly Assembled properly, new bump stops and raised a notch.
Front calipers not sliding properly, uneven wear on pads New discs and pads, all cleaned up.
Thermostat stuck open Stat Replaced
Coolant warning light flashes on occasions
Odd wheel bolts (mixture of tapered and radius) Sorted
Just been generally checking it over and such, working through it!
Have done so far:
Air filter
Plugs
Coolant
Stat
Front Top mounts
Rear bump stops
Front indicators
Side repeaters
Cleaned fuel pump (need to replace filter)
Adjusted rear brakes
Adjusted rear wheel bearings (were too tight)
Replaced discs and pads, cleaned up calipers so pads can move
Changed steering wheel
Changed head unit (wiring was a mess, fitted standard ISO connectors and got rid of mess)
And a few other bits and bobs, cant think!
The paint on this car is pretty clean, measured it with a depth gauge earlier and its original bar 2 small areas. However its very contaminted and flat, so will be getting a effort of a clean with snowfoam/clay/compounds/polish/sealant etc. In good time though.
Its a nice little car really, and the plans are:
Chassis:
New TCAs
Polybushed TCA's
G lader ARB blocks
PPP stage 2 subframe
OEM/Poly beam bushes
H&R 70/60 Spring and shock kit
New top mounts
New rear drums
Wheel bearings all round
New wheel cylinders + brake shoes
G40 calipers
Some form of uprated discs
Some form of uprated pads
Braided hoses
(Basically will be pretty fresh underneath!)
Engine:
Fit the AEE from 6n on carbs
Possible raised compression
Poly mounts
Trial the current gearbox and see how it goes
New 4-2-1 (current bent and dented from crash)
Eventually ITB's
Have a SS system made up
Exterior Shizzle:
Dewiper rear
DETAIL
Paint sills (below lower trim)
Standard (chrome) VW rear badge
Either chrome front badge, or badgless grill with VW motorsport badge offset
New number plates (pressed?)
Aero wiper blades - repaint wiper arms
Wheels iv just bought..read on.
Interior stuff:
Get some GT/G40 door cards
Oil temp + pressure gauges
Mount AFR gauge somewhere properly
Maybe a bracket/construction solely for extra switches/choke etc
Fire extinguisher (plumbed to engine bay)
So yeah...interested to see what all this early polo fuss is about so hey :)
Heres some pics :)
When I got it home ...
Some new bits...
Faffing about...
Exhaust was knocking a lot due to where it had broke, decided to change it about 9pm last night and naturally something had to break!
Tbh the exhaust has actually made a noticeable difference to performance, I was rather surprised!
Light changes...
At work...put 450 miles on this in the past week haha :(
Gave it a very quick wash earlier..looks quite shiny but the paint is so flat and contaminated (it looks cloudy!)
Interior...
Momo from 6n, genesis seats + headunit fitted
Picked these up this eve...are 14x6
Will be running 185/50, probably Conti's
Are going to be refurbed in shadow chrome, which will hopefully look nice :)
Am also going to space these a bit, but will decided when fitted how much etc!
I also got a base plate to start making another inlet..and will be getting some bodies this week..however will be a long term thing really!
Will also be fitting central locking at some point :) all in good time.
I might try getting all the suspension and the engine swapped ready for Poloshow...will just have to see as I have a LOT of college work on!
I had my other thread deleted and have started another due to epic amounts of spam and such!
So could we try keep this one a bit tidier please :)
Nick
  • Replies 831
  • Views 37k
Looking better already bro
Got a pair of front wheel bearing kits you can have for a tenner if you want them? They won't fit my mk1 hubs
Yeah, literally cannot stand the black front badge! Doing my head in haha.
And maybe dude, what brand are they?
Gonna order a lot of bits for once for this as apposed to bits and bobs spread over time :) save save save.
Anyone had any G40 calipers (carriers be good too!) drop me a PM please :)
Aint half crackin on like, did you get a stainless all the way through?
I was going to buy a white one, they look awsome with smoked front lights, side reps and black bandeds :)
Thanks mate, tbh the look I have in my head is like majority of others hHa, just pretty simple like.
Nah just a backbox for £28 delivered from ECP lol.
When the AEEs in will attach it to the stock exhaust first aha :)
Thanks mate,
Going for Polybushes as I think they'll be a bit more compliant than the G lader nylon items, however will run the ARB blocks for downpipe clearance :)
Can you get hold of new rear top mounts for these still?
Running alot of power through a standard exhaust will be nice and raspy!
My afh mk2 sounded lovely with a standard, just didnt look too nice! Lol
Progress os good buddy looking forward to more!
The old thread got deletred then?
Looks like good prgress to me :thumbsup:
Looking forward to the serious work being started 8-)
Yeah just get it up and running, small exhausts are often win for performance tbh!
I asked for it to be deleted as was a mess :)
Nice one man, glad to see you've got a new thread, I couldn't keep up with the old one. (touch wood it won't get ruined when B-shaw sees this :lol: )
Plans sound bang on! 8-)
Nice tidy looking car there, such a shame about the 6n but i think your AEE will be much more suited to the lighter mk3, so youll enjoy the car more =D
Cheers boys :)
Yeah like I said it is tidy, few little shitty bits and a few areas that look as though theyve been touched in with tipex, but with a good clean it should gleam :)
Just need to be careful as the paint is quite thin to be going at it with a mop !
EDIT..
Just ordered some dash speakers, some 6x4's for the rear and some speaker cable :) and a mirror glass :)
Edited by harris.racing
Looking good so far mate 8-) great progress you've made in little time! Glad to see you don't fuck about! haha
The conti's will look awesome when they're on too :thumbsup:
Looking forward to seeing more progress of this ^
No messing around with bits and peices then, youve got too much money you have :p
Working shifts and weekends to try get things moving mate!
More and more tempted towards coilovers
They yours ben?
And it all depends on what you want to use this for nicolas.
Whats made you think of coilies?
Just had a long phone call, can get some specced how I like, whatever springs and shorter rods for being a bit lower, £750 but about a month turn around.
And springs and shocks just leave you a bit stuck IMO.
Where from?
That price is ridiculous nick, make some yourself!
Gaz, philj charges that much for them?
they're expensive cause they're not cheap shit lol
I've totalled up the ones i'm fabbing up and they're about that price.
The differance is the springs/shocks are from "rally-designs" so i wouldnt call them budgets!
7" - 250lb front springs too!
I wouldnt make my own suspension lol.
other people are running gaz with good results, and a tailored package to suit your needs
If i made them it would be long term, i want stuff ASAP.
maybe an AP spring and shock kit for now or something
Well i wouldn't advise it if you can't weld no, or have no fabricating skills :lol:
No one knocked the gaz kits, and to be honest the price isn't too much taking into account the quality of their work and what they're actually making,
However £750 is a lot of money!, something that can be more than halved if you know what your doing.
What are you gonna use the car for? Buying coilovers is seems a bit of a waste of money if your running a frame. You'd be better off putting the money into a H&R kit and putting the saved money into something else.
But I want more of a drop than 60mm and adjustability?
I'm capable of making coilovers, I just don't want to at the minute.
At least with the gaz I can run shorter rods so I don't start bottoming dampers out, choose a softer spring for comfort, set my corner heights more accurately, adjust to a height I like not what just comes out the box...etc etc.
Lot of money yes, but I'm struggling to find the will just to buy a spring and shock kit, a decent one is still over £400, and you're stuck with that, at least I have some adjustability with coilovers, if the options there why not take it?
