Harris' Mk2f CL Coupe
hey i said id speak to them, not that id be able to get them cheaper haha, most of our stuff we have is prototype so I'm not sure 185/50/14 would fit a jag or land rover???
  • Replies 831
  • Views 37.1k
who knows :lol:
hmm what to do!
tomorrow i should have a stripped beam ready for powdercoat and a few other tings!
I haz buyed some stuffzzzzz pics to followw
From where bud?
Jeff Faulkes In Ibstock
bit of a trek
i think you might be hard pushed to find a dealer with 4 toyo's in stock
You still haven't brought tyres, all that discussion ahhaha.
p
But tbh, I spoke to my mate for about 3 hours trying to tell him what stretch was ahhaha. (the 1 with this famous mk1) He's a Porsche apprentice to
Edited by LiamMk6Polo
I don't want toyos haha.
Also shhh, tyres are the simplest thing to sort!
Need to finish building engine and refurb brakes and a rear beam!
Fair enough, when you having it done by? or just taking your time?
were gonna smash it all out one weekend before poloshow
My list is getting longer and longer mate,
I have a lot of college work I need to stop ignoring for a couple of weeks haha.
Poloshow no way, action maybe :/
dont be a gay. we shall stick to the plan. lol
ahah sounds good, Vw action in August? Might see you there hopefully :smirk:
This ain't gonna be done for poloshow, period! Haha
no faith. we could easily have the engine in.
It's all being done at once, or will be brakes/suspension first, then engine lol.
Eric want a strut brace?
Yes plzzz and cbr600s jetted for a 1.3 xxx
Gents- this is fast going the same way as the previous thread, Toby's/Max's/POLOMON's.
Please keep it as a build thread- not a chatroom, or I'll lock it and you can start a third...
Chassis
Coilovers - Ordered
Adjustable Top Mounts - Ordered
New TCAs - Got
Poly Bushes - Got
ARB Blocks - Need
GT/40 Beam - Got
Front Wheel Bearings - Got
Rear Wheel Bearings - Need
'Nick Bar' (fuck it they're a Ged bar so mines a Nick bar) - hopefully make soon
New complete track rods - Need
Steering damper - Got
New TCA fixings - Got
Lower rear damper fixings - Got
Brakes
Rear Drums - Need
Rear Shoes - Need
Rear Cylinders - Need
VWII Calipers - Got
Upgraded Discs - Need
Upgraded Pads - Need
Goodridge Braided hoses - Need
Caliper Seal Kit - Got
New Caliper bolts & sleeves - Got
Engine/Conversion
Headgasket - Got
Head bolts - Got
Mk3 Sump - Got
Mk3 oil pickup - Got (YAY)
Cambelt - Got
Flywheel bolts - Got
Rocker cover bolts - Got
New Vernier pulley - Got
New Rad - Need
Slim line fan - Ordered
Wiring loom - Need to make
Mk3 Temp sender - Need
Oil/Filter/Coolant - Need
Custom plate in centre consol for switches/AFR Gauge - Need to make
Fuel lines - Need
New throttle/choke cable - Ordered
Poly engine mounts - Got
New 4-2-1 - Ordered
Full exhaust (undecided whether custom or aftermarket) - Need
Cambelt cover - Need to modify due to lack of mk4 mount
Wheels
Powdercoat (Shadow Chrome) - Need
Tyres (185/50/14) - Need (probably Yoko's)
New Bolts + Lockers - Need
Centre caps - Need
Things to paint/powdercoat/refurb
Front Brakes - Red VHT paint
Rear beam - Black powdercoat
'Nick bar' - Black powdercoat
Front ARB - Paint
Slam Pannel - Flat and paint
Engine mounts - Black Powdercoat
Gearbox - New oil/Paint/New seals
Today I got:
Mk3 oil pickup
Upper strut brace
GT rear beam
GT/40 rack/steering damper
All engine and gearbox mounts
Mk3 alternator
Stripped the beam down, and played around with the alternator pulley situation.
Any excuse to play with fire
Stripped down
Mockup..
Gonna turn 7.3mm off the Mk4 alternator pulley to align
So I'm gonna have the following powdercoated black:
All engine + box mounts
Crank AUX belt pulley
Alternator adjuster
Engine lifting eyes
My brackets for holding carbs
Alternator fan
Rear beam
Drum brake back plates.
Will paint the alternator and starter just to tidy them up a bit.
Hopefully finish my lower brace and refurb the calipers over the next couple of weeks and get bits powdercoated.
Need to order some items such as
CV boots
New rad
Drums
Shoes
Cylinders
Handbrake cables
Wheel bearings
Etc.
Can get the engine back together now and crack on with things like making my little switch pannel and that.
Need to find out if I can bin the accumilator thing by the fuel pump and blank the return fuel line off (is there a vent stil?)
Nick
Edited by harris.racing
Just ordered:
Drums
Brake shoes
Rear wheel bearings
Rear cylinders
Rear hand brake cables
Shoe fitting kit
Outer CV joints
Rad
Temp sender
Both steering arms
For £200. £90 cheaper than Euro with the 25% off!
Saying that I get very good discount at GSF
Whats the difference with the gt beam? Is it that plate on either corner?
It just has an ARB, basically a piece of tube welded across to stiffen it up, I wanted to resto a beam so may aswel upgrade :)
I dont see no extra tube?
It's tucked up inside the 90degree bend bit mate. You cant in that pic :)
Oh rightt. I want to refurb a rear beam for mine just not sure if gt beam is worth it since i have a standard one on the silver coupe doing nothing
I think the holes are there in a standard be, buy a length of tube and weld it in?
