Harris' Mk2f CL Coupe
I'll probably get custom tbh, will get it made where I had my 6n one done. That was bloody perfect.
Probably just mate my 4-2-1 to the standard exhaust for now
  • Replies 831
  • Views 37.1k
If custom is only a little more expensive then I'd go for that all day long. I picked mine up second hand anyroad and have had to modify for the reasons above anyway. However, I've been lucky that i have a a friend who is able to weld and modify the pipe work for me. If i didn't, no doubt it would have cost a fair wedge to have it modified to fit
It's only money, lol
Wheel stud conversion? :)
ARRIS! want to swap rads?
i have a brand new diesel radiator which will fit your car and its larger then standard! uses the holes a bit wider apart on the radiator bar.
i cant use it as my intercooler piping makes my front end narrower
Hmm could do mate, mines just a standard one, I assume yours is a European diesel engine one that's why it fits the mounts or something?
Have just dropped off engine mounts and beam and a few other bits and bobs to be blasted and quoted. Expecting shit work for the price they quoted haha
*coated lol fail.
Tbh for a beam, and it was about 13 other small items like mounts and stuff I was expecting over £100 for blasting and coating, but yeah we shall see, some stuffs pretty pitted so wont be amazing but tidies it up and will hopefully be a bit better than me angrily throwing hammerite at them ahha :p
need to decide on what disc/pad setup!
also need to source some axle spacers..any ideas? :)
Chassis
Coilovers - Ordered
Adjustable Top Mounts - Got
New TCAs - Got
Poly Bushes - Got
ARB Blocks - Got
GT/40 Beam - Got
Front Wheel Bearings - Got
Rear Wheel Bearings - Got
'Nick Bar' (fuck it they're a Ged bar so mines a Nick bar) - hopefully make soon
New complete track rods - Got
Steering damper - Got
New TCA fixings - Got
Lower rear damper fixings - Got
Brakes
Rear Drums - Got
Rear Shoes - Got
Rear Cylinders - Need
VWII Calipers - Got
Upgraded Discs - Need
Upgraded Pads - Need
Goodridge Braided hoses - Need
Caliper Seal Kit - Got
New Caliper bolts & sleeves - Got
Engine/Conversion
Headgasket - Got
Head bolts - Got
Mk3 Sump - Got
Mk3 oil pickup - Got (YAY)
Cambelt - Got
Flywheel bolts - Got
Rocker cover bolts - Got
New Vernier pulley - Got
New Rad - Got
Slim line fan - Got
Wiring loom - Need to make
Mk3 Temp sender - Got
Oil/Filter/Coolant - Need
Custom plate in centre consol for switches/AFR Gauge - Need to make
Fuel lines - Need
New throttle/choke cable - Got
Poly engine mounts - Got
New 4-2-1 - Got
Full exhaust (undecided whether custom or aftermarket) - Need
Cambelt cover - Sorted
Wheels
Powdercoat (Shadow Chrome) - Need
Tyres (185/50/14) - Need (probably Yoko's)
New Bolts + Lockers - Stud conversion + red nuts ordered
Centre caps - Need
Things to paint/powdercoat/refurb
Front Brakes - Red VHT paint - done
Rear beam - Black powdercoat - on going
'Nick bar' - Black powdercoat - on going
Front ARB - Paint
Slam Pannel - Flat and paint
Engine mounts - Black Powdercoat - on going
Gearbox - New oil/Paint/New seals - got seals, need to source box
So iv ordered a wheel stud conversion lot, hopefully this week i shall:
Finish lower brace
Build calipers
Paint drums + fit bearings
Sandblast + paint rear stub axles
need to get some rear axle spacers, and a few other odds and sods, need t decide on a colour for brake hoses and a disc and pad setup
the rad that jim has in his mk2 is absoloutely massive lol, you should ask him for a pic! it may be the same one! think its the biggest you can get for the standard mounts
Edited by erixtar1992
haha my 12'' fan literally just fits the standard rad :p
I fitted a 6n2 valver fan and rad to my mk3, just cut the panel out of the slam panel and fitted it to the mk3 the fan is massive need to make a proper bracket up to fit the fan and rad, i'll put a picture on my build thread soon
its a euro rad harris- will fit perfect and i have the original brackets to use the original fan cowling!!!!!
its about 3" longer then standard for the same height and thickness. will make a big difference to the cooling mate.
i think it has a fee light scratchs but its never been used- i just tried to fit it and found it wont.
as for the coating- i had loads of stuff done at ABC and it was really good tbh. and cheap
haha surprised youve not made it fit tbh :p what brand is it?
as long as it will defo fit its not a problem.
i went to 3d finishing, i couldnt even find ABC's phone number lol
its to wide to get my intercooler piping in- i could do it if i made custom alloy pipes but i cant be arsed- now making an alloy rad.
brand is AKG germany. just been up in the loft and it is mint!
I seeeee.
Just drop me a text sometime mate.
Also little progress, have sand blasted and painted rear stub axles but no pics.
Damage to other pulley; little worse than this pic shows
Modded new one
Painted drums. Not amazing finish but I did no prep, will help with rust at least
Calipers baking to cure paint
Bit of carb surgery ;)
Thats not your mums oven is it?
How much did you pay for all the powdercoating? Just weighing up whether its worth buying a kit, or having it done professionally
Yeah? Why lol?
Also,
I'm getting:
Beam
Alternator fan
3 engine mounts
Engine mount plates (where bushes go into)
Gearbox mount plate
Engine lifting eyes
My carb brackets
Brake drum back plates.
That's blasted and coated, not sure if will be any good, but £45
Wow, thats dirt cheap. I'll look into that
Shouldn't really cure paint/powder coat in a domestic oven. Fumes are obviously released, and these shouldn't really be injested in cooked food. I wouldn't think once would do much harm, but I wouldn't keep using your old dears domestic appliance
Haha ah well, bit of immunity ;) it's like people who keep their houses overly clean have shit immunities haha.
They're done! Have cured a bit dark :(
It doesn't smell of anything in the house/oven so can't be too bad haha
EDIT:
Yeah it is cheap, am a bit concerned. Tbh the beam is pretty crusty so I wouldn't expect it to come out amazing. I told him that, but will be freshened up at least.
Brakes all fresh :)
Not dark actually I just didn't have a light on LOL
Edited by harris.racing
Look smart
looking good nick!
checked the jets on my cbr600s i have 4x135's! i have 2x138's and 2x140's, dont suppose you have 2 spare of each do you? x
I do yeah, Iv got 4 or 6 of each actually haha :) you could run 138 & 140, two cylinders run slightly leaner, can't remember if its inners or outers :)
awesome bro, I'm hoping 135's wont be to lean its only a 1.3 afterall. hmm. first start up tomorrow evening i hope!
Just do a plug chop at various points/loads
Right just ordered some braided hoses, discs and pads, discs were £130 so hopefully wont shatter like the one on my 6n haha.
Apart from sorting the wheels and tyres I virtually have everything near enough sourced now
