Harris' Mk2f CL Coupe
my idea consists of steel tube going across like before and the ends welded on at the correct angle so it will fit Nick! with the added bonus of angles going to the bottom of the chassis leg where the radiator bar lives. much better.
you have to bring the steel though as i aint got none left- only plate.
I'm sure i can sort you out toby
  • Replies 831
  • Views 37k
so would it be bolt in or welded on? lol, I'm just wondering about ARB clearance to the brace with G lader blocks
Chassis
Coilovers - Ordered
Adjustable Top Mounts - Ordered
New TCAs - Got
Poly Bushes - Got
ARB Blocks - Need
GT/40 Beam - Sourced
Front Wheel Bearings - Got
Rear Wheel Bearings - Need
'Nick Bar' (fuck it they're a Ged bar so mines a Nick bar) - hopefully make soon
New complete track rods - Need
Steering damper - Need
New TCA fixings - Ordered
Lower rear damper fixings - Ordered
Brakes
Rear Drums - Need
Rear Shoes - Need
Rear Cylinders - Need
VWII Calipers - Got
Upgraded Discs - Need
Upgraded Pads - Need
Goodridge Braided hoses - Need
Caliper Seal Kit - Ordered
New Caliper bolts & sleeves - Ordered
Engine/Conversion
Headgasket - Got
Head bolts - Got
Mk3 Sump - Got
Mk3 oil pickup - Need
Cambelt - Got
Flywheel bolts - Ordered
Rocker cover bolts - Ordered
New Vernier pulley - Got
New Rad - Need
Slim line fan - Need
Wiring loom - Need to make
Mk3 Temp sender - Need
Oil/Filter/Coolant - Need
Custom plate in centre consol for switches/AFR Gauge - Need to make
Fuel lines - Need
New throttle/choke cable - Need
Poly engine mounts - Got
New 4-2-1 - Ordered
Full exhaust (undecided whether custom or aftermarket) - Need
Cambelt cover - Need to modify due to lack of mk4 mount
Wheels
Powdercoat (Shadow Chrome) - Need
Tyres (185/50/14) - Need (probably Yoko's)
New Bolts + Lockers - Need
Centre caps - Need
Things to paint/powdercoat/refurb
Front Brakes - Red VHT paint
Rear beam - Black powdercoat
'Nick bar' - Black powdercoat
Front ARB - Paint
Slam Pannel - Flat and paint
Engine mounts - Black Powdercoat
Gearbox - New oil/Paint/New seals
So have sourced a few bits (HG, cambelt, headbolts, TCA's, manifold, seal kits, some fixings, oil filter and stuff like that)
This weekend I wanna:
Repaint block
Dust the head over
Paint dizzy
Refit head
Time engine up
But I'm also working now :S
it would be bolt on mate- but made on the car so it will fit and give the clearance you need
Bit of progress
Made my own timing marks so was a piece of cake
i have a steering damper.
Chassis
Coilovers - Ordered
New TCAs - Got
Poly Bushes - Got
ARB Blocks - Need
Brakes
Rear Drums - Need
Rear Shoes - Need
VWII Calipers - Got
Engine/Conversion
Headgasket - Got
Head bolts - Got
Mk3 Sump - Got
Cambelt - Got
New Rad - Need
Fuel lines - Need
New 4-2-1 - Ordered
Wheels
Centre caps - Need
Front ARB - Paint
Repaint block
Dust the head over
Paint dizzy
Refit head
Time engine up
Nick,
How much to powder coat a rear beam? and do they beadblast it before?
Iv no idea mate!
Different places have different methods,
Shot/sand/bead/vapour/soda blasting or acid dipping.
I need the beam, engine mounts, lower brace and a few other brackets etc just doing black as powdercoat is more durable than paint!
Hopefully I'll get all the bits I need soon and will get done!
Iv no idea mate!
I was just after a ball park price for having a rear beam powdercoated ?
40£ ish I'd guess?
40£ ish I'd guess?
:thumbsup: cheers, Hammerite it is then :lol:
haha, I hate paint and preparation
That's why I was looking at getting it powdercoated , get a replacement beam, send it away, hopefully bead blasted then powdercoated, fit powerflex bushes and then sling it onto the car :lol: just need new disc brake stub axles. The handbrake cables have been sourced from Mr RS251 (Robert Summerill) "on here" paid for 12 days ago, but so far he's ignoring any email contact :-(:-(
Minuscule update:
Built up my new TCAs with poly..
Also been messing around with IDEAS for a lower brace..
The first is currently on the car and is literally just a mockup, was gonna run two bolts either side but half hour break at work is limiting :)
Anyway it's 25mm tube with a 3mm wall pressed flat and bolted on.
Issues are that I think it sits too close to the ARB, well it would with ARB blocks I think..
Would need cutting to length properly and seams welding etc but yeah..
Another idea is like the GED bar things with a 90 deg bracket.
These are a bit longer to offset the brace to clear the ARB better.
Will bolt them on and weld the brace in place on the car, will be 25mm tube 4mm wall thickness..
Pens respresent the Bar if it isn't obvious!
Like I said these are just ideas and playing around so I probably don't need keyboard warriors informing me about weld penetration or whatever.
Tbh the one on ATM just tended to make it lockup easier, wheelspin easier and understeer in the wet, tightened it up yes but not really a benefit currently haha.
Also picking up a beam, alternator and engine mounts this week, so some bits can be powdercoated ;)
Just thinking wheels.
I'm going 185/50/14, so no need for two or three pages of that haha.
Shall I get:
Toyo's
Yoko A359's
Or Conti's.
Naturally the conti's are the most money, toyos the least.
Also not sure what centre caps to get... OEM VW or Wolfsburg ones?
And any ideas on rear hub spacer sizes I'd want?
I wanna just equal out the front rear offset differences, but I don't wanna rub or anything.
Wheels are 14x6 et33 I think, with 185/50.
At a guess I'd say 15mm per side? Maybe 20?
personally i would go with the conti's and OEM centres, but thats just my opinion
I'm swung toward the Conti's tbh, although they're £80 each haha.
Tomorrow ill have a mk3 oil pickup, upper strut brace, GT rear beam, G40 steering damper, full set of engien mounts (to powdercoat) mk3 alternator (can paint and mockup pulleys and such)
4-2-1 should be here wed, will also have new flywheel bolts, caliper seal kits, few random fixings and such.
Hopefully blast and paint the calipers over the next week or two, and finish my lower brace off.
Need to do one more bigish parts order for stuff for rebuilding beam etc, get a load of bits powdercoated, get tyers and upgraded brake bits then should be about there!
CLs dont have a rear compensator valve do they? I cant see one
only GT/G40 i think mate
none of my cl's did however the GT did :)
Thought so, not an issue :) will just bin it off the G40 beam haha.
Just ordered:
Slim fan,
Stainless bolts
Throttle cable
Choke cable
Glass fuel filter
Caliper paint
Gearbox seal kit
Fuel hose reducer
few other bits and bobs, all little shitty bits that add up!
as i said on fb, contis.. they were the best mod i did to my 16v.
Shall I get:
Toyo's
Yoko A359's
Or Conti's.
I Just went for some 185/50/14's and i went for Conti's
Managed to get them £60 a Corner
They are alright in the wet too!
From where bud?
Contis FTW!
Although tbh, yoko and toyo are amazing also, but the contis seem to be the best all round for wear/grip. Other two wear fast!
Conti it is then, will speak to them direct at work as we use them lots and lots and lots
know where to come when i need some cheap ones then :lol:
