Mk5 Polo Trims
So I'm after some SE colour matched trims for my 6n2 red polo, I have the E model and hate having black door trims, any idea where I can buy some new ones? Don't really want to take them off to spray them but I will if I have too.
Edited by Mat Smith
  • Replies 10
  • Views 1.7k
If you mean the exterior door trims aka bump stops I'm sure I read you can't remove them so your only option would be a spray on the car! Masked off neatly!
pretty sure they can be removed as they are just on with a double sided sticky tape but you will have to spray I'm afraid, looking about £50 to have a proper place do them
or buy some off someone who is breaking a car the same colour.
I got a set off here for £20 posted
Yeah would be cool if I could get some from scrappers or something but I dunno, thought there might be somewhere I could but them new, if not ill just have to spray them, no idea how they are attached though
double sided tape
they are taped on with the 6n 6n2 is clips.
Are they easy to clip on/off? or am I gonna end up snapping the clips getting them off :lol:
held on by adhesive so can be taken off altho you will be left with alignment holes along the panels as tey are used to make sure the strips are straight. my mate recently sprayed his body colour and did it wil £30 werth of paint primer and laquer is a really good job aslong as you do all the correct prep work before hand. and have masked off the panels surrounding..
Saunders
Saunders
So you reckon I could just take them off and do a decent job spraying then just put them back on fine?
