6n Coilovers, 256mm Brake conversion
Yo.
Breaking my car...
Got a set of JOM coilovers, used but not seized...have shorter stiffer spring aids (bump stops) helpers available too.
Fronts recently had new top mounts and bearings.
£80 collected.
Also have a recently completed 256mm brake conversion.
16v hubs, new wheel bearings, blasted and painted calipers, resealed, OEM pads and drilled/grooved discs, new jump hoses.
Have done about 2000 miles.
£100.
Cost over £200 to do.
Please note, I will need to check these parts over due to the accident, but as it snapped the bottom ball joint id imagine that took most the force.
please PM me !
Nick
  • Replies 8
  • Views 408
Have you got any pics of the coilovers mate?
How much delivered for coilovers?
Not sure what they cost to post due to size/weight.
And no pics atm, they're on the car which is covered up etc
Just found this..can kinda see coilovers and the brakes when were fitted
Bump!!
This was the brakes before fitting.
Will remove brakes and coilovers friday.
Brakes were blasted, painted, genuine seals, genuine pads, new wheel bearings in hubs.
Drive flanges included.
New caliper bolts were used too
will the brakes fit my 1986 mk2 polo breadvan? or is this a 6n thing only?
They wouldn't mate no :(
Also,
Front coilovers damaged
Rears sold
Brakes sold
