windows- electric to manual
right, I've had enough of the electric windows packing in on my 6n2 gti,
is it a direct fit if i wanna use manual window mech??
  • Views 872
Yeah man, you've got no wiring to deal with. The runners bolt up to the same holes.
You'll need the doorcards too, so it might look out of place with red ones in the back?..
Don't cut the wiring either, you might wanna go back to them.. The switches are the problem, get them damp at all and the freak out. They're not hard to strip down and clean though. And the wiring from the car to the door suffers from splits. Mine've work for ages.
cool man, I'm gunna rip the fuck out of the old ones and cut the wiring :D
had enough of them not going up, clips breakin, motors packing in, switches fucking up all the time, jut want to b able to wind them up by hand and know there gunna go up :)
also, do you know if 6n ones will fit a 6n2? :/
DONT CUT THE WIRING! Theres no need, just tie it up out the way; what if you/or someone else after you wants them back. No need to chop them just because it's redundant.
I've just build a new engine loom using only the wires I need; but I didn't chop the old one, JUST INCASE i decide I wanna go back. So it's wrapped up and tucked out the way..
Not too sure. Think the doors are pretty similar though. The internals MIGHT be the same, but the cards aren't..
