Polo 6n1 Door Locks and Handle repair advice
Hi,
I've acquired a VW Polo (T reg) which I believe is a 6n1?
Anyway, there are a few things wrong with it which I need to sort. One of which is the door locks. The drivers door lock itself comes completely out of the door if you try to use it, and it doesn't lock the door. The passenger side has a different key which also, doesn't work. The boot lock and ignition work fine.
Now obviously the central locking doesn't work either. What is my best option? I would of prefered to rebuild the locks, but as the passenger side has a seperate key, I'm thinking it best to replace both the drivers door and passenger door locks.
Would something like this be ok?
http://www.amazon.co.uk/Front-Handle-94-19...6854&sr=8-1
I was told by someone that I need to make sure the locks are of a specific type, or my central locking wont work, is this true?
My ignition key is a flat key, but the replacement lock in the passenger side is a jagged key if that makes sense?
Also, the drivers side electric window doesn't work either :( is this a common motor fault or are there other common issues with them? I will take the door card and have a prod around with the volt meter to see whats what.
Thanks in advance :)
Edited by PageyUK
  • Views 1k
Anyone?
