Engine cover spraying help!
I gt a 1.8t polo 9n3 and I want to spray the engine cover but will I need heat resistant paint? And what grade sand paper would I use?
Thanks for your help
  • Views 1.5k
if your refering to the plastic cover then there is a process to getting a good result, use solvent degreaser and red scotch brite to key up the cover, ensure its dry and clean then apply a good coat of plastic primer, leave to dry then apply 3/4 good coats of 2k high build primer and leave to dry totaly. then me personaly flatt it off with 400 grade dry and add another 3 coats of primer leave to dry then flat with 400grade dry the same as before, this will just ensure a nuce smooth coat and will hopefully prevent it pulling in with the heat, once flatted off simply paint with usual car paint, either solvent or water based and then laquer as you would do a bumper or body pannel, no need for heat resistant paint as these are only realy needed on the engine block, and before people start, i have painted loads of rocker covers for various cars and so long as there preped correctly the heat isnt an issue, hope you get the job done and add some pics of it when its done
Thanks for the reply mate! I will get started tomorow :) il deffo put some piccys up when I'm done thanks for the advice :)
