"Check Engine" Light Intermittently Coming On
I have a 2001 6N2 1.4 8v and I took it to "Kwik" Fit to get a free exhaust check before my MOT to see if it had any holes, they shown me it and it was all in good condition. So job done. But then when I pulled off from the branch, the check engine light illuminated! Then a couple days later I started the car and it went off so thought maybe it was just where they were banging the exhaust, and thought nothing else of it. Then a few days later it came on again, and went off a couple of days later... And you guessed it, it's come back on again when I started the engine up last night. Anyone have any ideas? Any sensors on the exhaust under the car that could have become loose when they were banging the exhaust?
Any advice appreciated :)
  • Replies 10
  • Views 1.5k
My light comes on in the wet...and living in Scotland...it's on almost all the time :lol:
I keep one of those reset tools in the glove box and switch it off when it comes on...
Can't remember the code that shows up off hand but it's the lambda sensor...
Edited by buster.g40
Ye I was thinking lambda sensor, but there's only the one (isn't there?) and that's in the engine bay by the exhaust manifold and they didn't check in there. I've had a play around with the connections, and they are all fine. Maybe I'll reset the fault codes and then see if it comes back.
You can get a cheap obd2 reader on ebay for like £20 can't you? Do you know if they are any good?
Yeah...sorry...it's the one in the manifold that shows the fault.
Depending on the engine code you might have two lambda sensors one before the cat and one after it
Thanks. My engine code is AUD, do you know if this has 2 lambda sensors?
Yes you have two sensors
I bought one of those cheap vagcom leads off ebay and got it to work tonight, and it came up with the following:
VAG-COM Version: Release 409.1-US
Chassis Type: 6N - VW Polo
Scan: 01,02,03,08,15,17,19,25,35,41,45,46,55
Address 01: Engine
Controller: 030 906 032 CG
Component: ME7.5.10 3622
Coding: 00031
Shop #: WSC 00788
4 Faults Found:
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-00 - -
16804 - Shareware Version. To Decode all DTCs
P0420 - 35-00 - Please Register/Activate
18010 - Shareware Version. To Decode all DTCs
P1602 - 35-10 - Please Register/Activate - Intermittent
16519 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit Malfunction
P0135 - 35-10 - - - Intermittent
Readiness: 0000 0000
I cleared the fault, started the engine, and then re-read it, and no fault came. Any ideas if this means its game over for the lambda sensor?
If it has cleared and now no faults are showing it looks like it's OK but re-scan again after a few miles and see if it has re-occured it might be the wires from the front sensor are intermittant or when the exhaust place did their checks they "accidently" disconnected the connector so intoducing the fault codes in the hope of fleecing you for an unnessessary repair!!
Ye I'll check the wiring on it today. Do you know if the AUD 1.4 8v engine has 1 or 2 lambda sensors?
Check previous posting :lol: Yes the AUD has two lambda sensors
