New Febi Top Mounts £7, Bump Stops£2.50 Castle Nuts £1.50- Goood Prices Will Be At Bvf
Able to get these at a decent price - german made by febi bilstein and brand new
Top mounts £7 each
g40 spec bump stops £2.50 each
castle nuts £1.50 each
postage £4.50 for either bump stops or a full set. if you want just bumps etc... let me know.
PM me if you're interested
pete
Edited by PeteG40
  • Replies 63
  • Views 2.8k
Hi, do the top mounts have the bearings in? Thanks
yeah, top mounts is rubber and bearing in one unit
yes will have some top mounts if i can use them for a 91 gt coupe
sure can!
Will have a set at end of month Pete (Y) ..
whats the best you can do for the whole job posted ??
Cheers!
i can't do any cheaper than £26.50 a set posted
pete
Good prices these. Like for like aftermarket parts febi are the best i have used.
:thumbsup:
pete
Hi you posted mine mate ?
posted yesterday maz!
Ill send you over some money at end of month mate :) .. Hopefully should still have some by then, I bought a few things off you before so you know I'm good for it ;) haha
yes man i got them top man
bumpage!
Still available mate ??
If so i'll have a set off you today..
How longs the turn around btw?
sorry been away - yes in stock, can post weds so be with you fri probably
i need a full set :)
Not sure if i have asked you before but can you get rear bumpstops ?
You can buy poly rears from eBay if that helps.
hi mate - can get rear bump stops (not top mounts) at £8.50 each.
expecting a load more of these in together with axle bushes and front window seals.
Front windscreen seals are £15 each and rear axle bushes £4 each
Edited by PeteG40
Are they OEM genuine items ??
no they are made by FEBI bilstein as above
Sorry i just thought when i posted haha, 4 quid for axel bushes .. Thats cheap :o
When you expecting some, put me down for a pair
Hey Peter I'll take the set for 26.50 posted In a week or two
