28mm rear axel spacers
Are made for a mk3, unsure if it will fit others? This is a set of 2spacers and 8 longer bolts £30
  • Replies 8
  • Views 329
What are these used to do buddy?
Space rear wheels. But instead of going between the wheel and hub, they go between the rear axle beam and stub axles (behind the drum brakes on most cars). IIRC these fit all polos upto and including the 6n2 amongst other VAG models
Is that 28mm per side boss?
Thank you! and yes its 28mm each side
£30 delivered?
Postage is £8.80
£35 posted?
Sold!
Arrived today safe and sound. Cheers ;)
