HELP! Door Check Strap Replacement? 6n2 GTi
Hi, can anyone advise on where to look (apart from stealerships) to find a replacement door check strap for my 3 door GTI? Its for the passenger side, pretty knackered as it sends out a pretty noticable CLICK about halfway on opening and closing the door.
Any help on sourcing this part would be much appreciated ( and any pointers on fitting it appreciated even more?)
Jack
  • Views 1.3k
just try the dealers, not going to be anything over £20 i wouldnt have thought, other than that its a case of getting a 2nd hand one which is a bit tight in my eyes, there easyto swap over, no more than a 20min job tops, buy a new one and keep it greased
pointers on fitting, door card off, undo nuts, remove through door pannel and replace with new, its very streight forward when you get into it
9) 6N0837249 check rod - door / F 6N-YD509 001>>* / F 6N-YY517 001>>* / also use: *>>6N-YD509000 *>>6N-YY517000 6N4 839 281 6N4 839 282 1H4 839 257 C
(9) 6N0837249A check rod - door left / "D..": post
Listed @ 14.9 €uros
Cheers for the pointers guys, actually just gave her a wash and wax seen as the weathers so good and decided to get the door card off and have a look myself...turns out it was just a couple of loose bolts that needed tightening so happy days!
