A few things to work out..
Hi guys,
I'm new to the forum, after having just bought myself a 1.3 Mk2F polo, bit of an impulse buy but its in such good condition I couldn't say no :)
Unfortunately my mind has already started rolling about some little mods, first of all I need a roof rack for my work, are these readily available at reasonable prices? And anyone got them? easy to fit e.t.c.?
Also, I don't suppose the mk2 golf front will fit? Might be a little experiment, I'm not sure if it will look good or not, if someone's got any pics would be great.
one more thing, am I right to believe the suspension set up on a mk3 polo is the same as a mk2F? or is that just rubbish?
Sorry for all the questions, but after having owned a few VR's and various dubs, I cant wait to start modding :)
Thanks all,
Dave
  • Views 964
MK3 (6N) and MK2F (86C) suspension is not interchangeable. The rear struts can be made to fit but the front is a non-starter - 6n front suspension is basically the same wishbone design with bolt on struts the Golf always used, all Polos were given stoneage iron arms with one-piece struts, using inserts, until 1995.
Also from the stoneage - roof gutters. Ideal for mounting old skool universal roof racks. Alternatively, there are bolt-on rails for the car but this means drilling holes in the roof skin, so it's a permanent fixture.
Very few Golf parts will fit the Polo, no front end trim at all, it's all on another scale from the tiny Polo.
Ok, Thanks for the advice, (Sorry for the late reply, I thought it would email me when there was a reply!)
So I'm basically looking for just 86c suspension? What about exhaust hangars? Are they not interchangeable? I only ask becuase I'm finding parts a bit hard to find..
http://www.clubpolo.co.uk/forum/index.php?showforum=84
Plenty of MK2f (or MK3 as this place used to call it) parts can be found or at least looked at to get an idea of what your after including a few different types and price ranges of suspension and coilovers.
What part of the hanger do you need? If its the rubbers than any exhaust rubber holders work fine, if its the part welded to the car then i believe you can still get a replacement from a decent VW dealer. There is a guide in the FAQ to fit it without welding.
Just depends what exactly your after really.
Ok thanks guys, I'll soon be breaking out the credit card then soon! ;)
Sorry by exhaust hangars, I meant exhaust hangar placements? because I want to be changing my exhaust to make a bit more throaty..
You need to remove the whole Golf thing out of your head. They couldn't be more different. They share the wheelbolts, oil cap, and sump plug - that's about it.
They have been deliberately engineered to be completely incompatible, and the exhaust is no exception.
A Corsa will probably make a better parts donor, or experience mule, than a Golf.
I've had Astra and 206 rear exhaust boxes on my MK2, and even a Powerflow from a 2.5 V6 Vectra, and despite needing the mig, none were harder than trying to make a MK2 Golf GTi 8v box fit.
Haha ok, I'll forget that idea! I'll definitely be lowering it when I get some new wheels (decisions decisions!) becuase hey, its a Vdub right? ;)
