Hello from USA
Hello Guys, My name is Joe.. I live in New Jersey USA.. i was born and raised in Brazil.. not too long ago a friend of mine bought a 1982 vw polo that was imported to the states.. and when he didnt want it anymore... i sure had to jump on it...
here are the details:
1982 Volkswagen Polo CL
HB engine code.. 1.1L if I'm not mistaking?
GW trans. code.. 4 speed
LA3B original paint
81k miles all original
checkered beige interior with brown
here are some pics.
308493_10150358106813953_730783952_82573
384685_222545807813575_118208164914007_4
392106_292924757418844_121015521276436_9
i currently have a few carbs problems.. and distributor.. i need to get parts from England here.. anyone know a good source?
and has anyone attempted in doing a 2.0 ABA engine swap to those cars from the MK3 vw bora?
any input is greatly appreciated!
and this site has a great amount of good info.. keep it up :thumbsup:
  • Replies 65
  • Views 6.4k
Wow welcome aboard! Think you must be one of the 1st from America on here, well at least what I have come across.
At least the steering wheel is on the correct side :nod::thumbsup:
Welcome! I don't actually have a vast amount of knowledge when it comes to mk2s but damn all that sun has done her good
Woah imported to the states, your mk2 must be so rare like no other car.
Good to hear to have an outpost on another continent, greetings... err yeah from germany.
cheers
Christian6N
welcome.
awesome - a side exit exhaust polo bready and right hand drive in the US of A
nice car, and good bodywork bud
hey guys.. thanks for the warm welcome.. this polo is one of the first in USA.. i believe it was the 2nd imported.. and one of the only ones legally here and registered..
its very rare and people point and stare.. I get a lot of compliments on it.. its a very clean car and garage kept.. I have new bbs wheels for it now.. 15x7.5 front and 15x8 rear.. 1" lip from and 2" lip rear.. will post some pics of that when i actually fix the problems and get it out of the garage.
i dont have to worry about emissions with the car here since its registered as a classic.. so the side exit was done pretty easily :)
and i need the following parts
temperature regulator
036 129 828
bosh ignition coil
171 905 115
and the entire distributor
036 905 205 G
with the cap and vacuum time advance
and all the spark plug wires
anyone willing to ship to usa? i got a paypal
What are the carb and distributor problems?
Engine code HB is the pre Formel-E model up to chassis 799999
If Brasil model is the same it has a Solex (later Pierburg) 31 PIC-7 carb with these specs
Part number 052129017A
25.5 mm venturi
main jet x132.5
air corrector 105v
idle jet 42.5
idle air 90
enrichment 30
enrichment air bleed 100
accelerator pump volume 0.9 cm3 per stroke
needle valve 1.5
cold idle speed 2300 to 2500rpm
choke air gap 1.8 to 2.2mm
choke air gap (pulled down) 3.7 to 4.3mm
Might just bees the 20 year old rubber bits replacing.
Eurocarb Ltd www.dellorto.co.uk do a service kit for 34PICT7 which should fit
Service kit
Though they are dellorto specialists I've bought parts from them before and had good service.
Holy poop, another MK2 Polo in the US - That's at least three over there. I see you've been running it's British registration for a while :p
Wait WTF. JHO126X is SORN until 2013 and is not marked as exported...
That is so nice! Paintwork is amazing!
This... is awesome!!!
It must get so much attention? and so many funny looks? lol
I don't have any of those parts, but someone needs to help this guy out!
Can VW not get them for you from your end? We can get stuff from Germany if we badger them enough :lol:
036 905 205 G
Distributors don't normally fail. New rotor arm, POINTS, cap and leads will normally sorts it.
So fairly rare item I'd guess. Well the vacuum advance could I suppose. Put a new post in the parts wanted section?
Or German ebay? International buyers welcome says this listing.
(Gebraucht is used)
clicky
Edited by dvderlm
Welcome aboard! Nice to see a Mark2 over there. Looks in great condition!
Regarding your technical query with the future engine plans:
It's not been attempted over here. Generally speaking its quite a lot of work to fit a tall block engine into the earlier Polos, and requires a subframe to be bought or fabricated for the purpose of fitting the tall block. A company in Germany called Salzmann offer a subframe, but its more geared towards fitting a 1.8 turbo lump from say a Mark4 Golf.
One of the main drawbacks to fitting a tall block is it puts a lot of extra weight over the front of the car and upsets what little balance the car already has. One of the more favoured ebgines is a 1.6 which you should be able to find over there in a Mark3 Golf. Engine code AEE or even ABU. They won't set the world on fire at 75bhp, but it should be more of a straight fit, and with the addition of some bike carbs and a freer flowing exhaust manifold and downpipe you might see around 90-100bhp.
25.5 mm venturi
main jet x132.5
air corrector 105v
idle jet 42.5
idle air 90
enrichment 30
needle valve 1.5
Service kit
it started dying on me.. until i parked it and it didnt start anymore.. the carburator itself was rebuilt when it came over.. so its pretty good besides the choke was a little hard and got stuck.. but it was fixed.. the distributor was full of oil and the points are bad..
here in some states you dont need a front licence plate.. so we can run "ornamental" ones like the original one.. and i dont see why its not marked as exported as i have all the paperwork proving it was done legally.
thanks man.. i too was surprised the first time i saw it how clean the paint is.. it was bought in England from the widow of the original owner.. and he took good care of it.
it gets tons of attention and looks.. people pull out phones and take pictures.. stare and point at it.. it gets funny sometimes to see the reactions.
the vw dealers here dont get access to any of the stuff i need.. i tried everything and everywhere.. my last resort is someone from England helping me.. i seriously would send a paypal to whoever would help find the stuff and ship it over.
for the next winter project I will attempt the 2.0 8v aba swap to it with turbo.. I just dont know how much room i got.. how is the bay size compared to a mkI rabbit?
How recent was the import?
Welcome chap.
Your mk2 looks so nice. shame our laws are stricter than yours. running no front plate would make several of our lives alot easier :nod:
I'm sure one of more technically minded members will be able to sort you out ;)
ditch the points and fit an accuspark kit. much better!
036 905 205 G
(Gebraucht is used)
clicky
hey thanks for posting this.. its the exact same one i have.. mine is all apart now... i asked a friend to sand blast it for me.. turns out that he may know a guy that could rebuild mine.. i just dont know if he will be able to.. otherwise i will have to buy from over the pond!
from what i been looking at.. its quite possible to even mount to stock mounts with some adapters... seems pretty straight forward.. and since i will be running a short ram intake.. i will have some extra clearence!
very recent! i think it made to the states in november or so
Welcome chap.
i hear you on that.. i just love rocking the english plate upfront.. its different here!
any more info on that? where can i get it? is it reliable? thanks for the input!!!
Hmm, maybe the DVLA is just being slow.
The early ones are the ones to have so you did well in that respect!
its a good mod, search it up on google, done with magnets so no need to adjust points ever again and it runs better and smoother!
Edited by erixtar1992
Hello and welcome..
yep this must be about the 3rd Mk2 in the US, and perhaps the 2nd British one. Both of mine will be coming back to the US with me in 2014 when they finally become 25years old.
I might need to create a US section on here! :)
As for parts EuroCarParts do ship internationally and your US VW dealer can order European parts but you may need to show the correct importation documents for them do so.. and they take a while for them to turn up. Also there is a guy in the US organises a container every now and then and fills it full of European parts which is good for the larger stuff
But if you need anything specific please let me know and I'll try and sort it out for you!! :)
You can get a new distributor from EuroCarParts which I think costs about £130 so circa $200 but you need to make sure its the right one as it took them 3 attempts! :)
If you don't mind me asking who are you insured with and did you have any problems?
There is a green mk1 in the USA too. Someone might remember the chaps user name...I don't...
This car is cute, should be plenty of people who can help you get the right parts bud.
It was DezUU or something like that. But I'm sure he has sold it now. I'm sure there was a picture in PVW in the news section and it was a story about a new business in the US and they were shipping European parts and the picture had a mk2 in a container surrounds by parts.. :) it might have been this one actually!
15s look too big. other than that looks cool.
