2009 Polo door card
Hi guys
There is a rattle from the top front of the door in this Polo - can anyone tell me how to go about removing the door card?
There are several screws at the bottom of the door, plus some pegs I can see up the sides, but it's the top half I'm really unsure about. It would be amazing if I could just get the dark grey panel off without bothering with the lower part!
Any help would be much appreciated. Thanks in advance.
  • Views 1.3k
Unfortunately the whole door card has to come off
1. Remove the door handle and switch: by simply prying it up near the switches and work round.
2. Unplug window switch.
3. You will then see 2 torx bolts on the handle part (remove these)
4. Remove the screws along the bottom of the door
5. Then pry off the door card starting at the bottom corner (end nearest to back end of car) and then work your way around (may take some force but don't be scared)
6. Lift door card free of window channel (again some force may be required and remove all plugs to door
7. Fit in reverse order
Liam
With number 1 I mean the plastic panel it sits in needs to be pryed up, not just the switch
I had the same problem on my 6r. It was the runners that were rattling the windows.
Cheers guys. I'll tackle it one fine weekend and let you know of any major problems.
polo04: by number 2, do you mean the whole black handle part - the window switches come out with it, do they?
Edited by DavidJTaylor
You pry up the black plastic that the switch sits in, the switch will come off with this and there will be a plug plugged into the bottom and then unclip the plug and then put the switch and shroud out of the way.
And although this may sound difficult, it's not, when I first removed the door card (I had no experience and didn't know what needed to be removed) it took me about 15-20mins to remove it and slightly longer to put back in, so this should be able to be done in about an hour
Edited by polo04
