Would a gt head make a differance?
I have a 1.3 genisis (mpi) breadvan and I was just wounding if I got a polo gt head would it...
-Bold straight on with none or minor changes?
-Make it quicker?
-Worth doing or more hastle than its worth?
  • Views 669
-Make it quicker?
if you fit gt head with CAM than YES you will notice diverence.
As far i remember is plug and play, don't forget to skim the head, also you should use new head bolts and gasket.
or just install GT cam (you save few £ as you will keep tour head)
think the only diference between your head and GT one is valve springs and CAM
Edited by Adamos_20
So if I just fitted a GT cam is it about the same power improvment and I wouldn't have to change anything else apart from the cam?
YES
Okay, Cheers lad :)
Heads the same, Cam is the only real difference, some GT's also had double valve springs.
Just swap the cam over, but then its always useful to have a spare head lying around.
