Help! Driver's door won't open!
Hi guys,
I have a 6N and a headache. 2 days ago, the driver's door refused to open, and hasn't done since. It opens fine from the inside with a pull of the handle, but from the outside I got nothing.
Worryingly, my MOT is due on the 30th of this month, and I don't have a lot of money as it is, so I would like to have a go at fixing it myself as I fear the repair might be more than I can afford. Before I take the door card off and open up Pandora's box of sh*t, has anyone here repaired this problem successfully before? Is it straighttforward enough, and what tools do I need?
Any help or advice would be hugely appreciated guys.
  • Views 777
Sounds like the outside handle has just come off from the lever. If you pull the door card off you will be able to see handle from inside the door. And you will see a lever that will be sitting next to the habdle it needs to be sitting on th hook off the handle to open th door bassicly slide it on and its done. Pretty simple soz about my explanation. Down to the point its easy and you need a phillips screwdriver for the door card and maybe a t30 tourque bit to undow the handle to jigggly it about
Wow, is that it? That sounds almost too easy! I might as well give it a bash. Will let you know how it goes.
Thanks mate!
Yeah man let me no
