Bonnet Bra Lacquer Bubbles
took the bonnet bra off today after the car being garaged and kept relatively clean for a good month, to clean underneath it. there was a little bit of paint wear where the bonnet bra rubs as i expected, also expected that to t-cut out...
but then i noticed a small bit of lacquer bubbling. and then i traced it along the bonnet and sure enough theres a whole line of it. i knew bonnet bra's held mouisture etc fairly well but shit..
:crybaby:
lesson learnt - don't buy a bonnet bra for daily use if you like having half decent paint on your bonnet. for now, the bra's going back on over it to hide it away, but next car I get i wont even touch one of the bastards. :thumbsdown:
  • Replies 9
  • Views 1.7k
When I bought my bonnet bra it came with instructions, sayIng every week regardless of weather conditions, remove and leave to air dry for 24hours
So this could be your problem ? Although the car is not being used, the bra will still be getting the same amount of moisture as you would driving it.
Liam
.... and the reasons I'll never buy one.
Arnt they suposed the protect the paint? from chips etc
seems u came off worse.
^^^Yep but there not designed for constant use.
Also if the paint wasn't pristine clean and well waxed or quick detailed before fitting then chances that will damage the paint as well.
And thats why i hate bonnet Bras. Alot of people only use them to hide crap paint anyway. Car covers have the same affect, but on the whole car if you leave them on. A guy i know from the shows has a splitty, and he kept it under a cover for a while, when the cover came off, his whole roof was covered in micro blisters...
They make the paint sweat and are generally just a bad idea unless being used as intended, for short periods of time when you are tracking alone motorways ect to protect against stone chips
I only tend to use my bra when going to a show on the motorway. Also as said in previous posts make sure your car is clean and has a good coat of wax on too. Leaving them on for a long time in all elements can cause serious damage to your paint.
nothing worse then a moldy bra..
Moterway use is the noly reason i have one :)
Literally leave mine on for a few hours at a time when going to uni on the motorway, dread this happening to me :thumbsdown:
