MOT advice
Hey all just passed my MOT but have been given a list of things to do soon they are:
Front brake pads as worn 75-80% - £139 inc VAT.
Front lower arm rear bushes split - £338 inc VAT
Cambelt due every 4 years or 60k - £329 inc VAT
My gti is on a 56 plate but only done 36k miles, why does the cambelt require replacing with so little miles?
Please help and are my quotes about right?
Cheers Dorey
  • Replies 10
  • Views 2.9k
sounds like your gonna get reamed. TBH i wouldn't use vw for any of those jobs listed above, you'll pay over the odds. Better to use a specialist or known good local garage. age of a cambelt is as important as the use it has had, hence it needing replacing every 4 years or 60k, whichever comes 1st
cool thanks what sort of prices for the jobs above are good value?
rang a few garages and have some better prices..
brake pads + cambelt is £230 inc VAT
suspension bushes (pair) £128 inc VAT
only problem is they are at 2 different places.. hay can't grumble at that
moral of this story.. VW quote high as they cba to do the work.
From experience , thats not a bad price for the bushes
my 9N ones i ended up fitting cupra ones , bloody nightmare if you dont have the right gear
For £128 personaly i think thats very reasonsable
I was quoted between £250 and £300 for lower console bushes
well , they just replace the whole arm with the crappy hex bushes
the quote for cambelt and pads seems reasonable too if its all done by a propper garage
Edited by mpsheen
Get the cambelt done at a proper garage, the brake pads do yourself.. and the bushes if youve got some basic skills are fairly easy to change!
i do agree i did my own bushes n i replaced them all with powerflex there so much easier to put in :) changed all my brakes and did the ARB aswel. the polo 9n3 are reali easy to work on. x
Research prices of parts, Ask on how much labour will be at specialist garages/ good 1's. Resulting in finding cheap labour, ask how much to do the whole job including parts, If your parts/ there labour come in cheaper then try and provide the parts your self. You can end up saving a few £100 and you get what parts you wont. Ie Brembo disc's/pads instead of genuine.
Edited by LiamMk6Polo
Any idea how hard it is to change cambelt? Doing brakes and brough bushes although not 100% on them, couple of guides if anyone has would be very helpful.
If you're in any doubt, I personally wouldn't DIY the cambelt on a 1.8T. Brake pads ought to be easy enough, just get a mate who knows what they're doing to look over your shoulder. Make sure you get the right ones though because from memory there was about 3 or 4 different types of caliper fitted on 9n3's last time I looked it up.
ok, I'm doing pads with a friend they are in the post. bushes ordered but not sure if i can fit them may find a friendly garage or see if local college can do it. cambelt I'll leave alone then as its a big mess if anything goes wrong
cheers
