Newbie with 6N2 Polo Gti bearing noise
I am new to the forum as we have recently baught a Polo Gti. It came from a dealer who had the gearbox rebuilt and have receipt. I know the garage as I am in the trade and he is one of my customers. The issue I have is a loud bearing sound at arond 20 mph which gets quieter but is a whining sound at speed. They can't find anything and so I jacked up all the wheels and checked for play and spun all of them....no sign of any play or sounds. I am at a loss of what it could be? Could the Fortuna Sport F3000 tyres be that noisy? Could it be a drive shaft/cv joint? Even though there is no play could it still be a bearing? I am stumped and just wondering if anyone has any ideas?
  • Views 965
It's hard to tell in the car, let alone in text. But generally, you'd have some idea.
C.V's aren't a consistent sound.
Wheel bearing drone is just that, a drone. Bone deep and responding most to slight steering corrections. I mention wheel bearings because there's little else that whines consistently at stable speed.
Diferentials do, mainly when on the back axle but it's all the same in a front drive gearbox. Diff bearings, input shaft bearings, output shaft bearings, if it's going on in a Polo it's going on inside that one unit. Thrust bearing is gonna change with the clutch pedal. Alternator with revs out of gear.
If it's only in gear and and reacts only really to speed, it's a gearbox bearing of some sort.
Switched front wheels to back and noise has gone. Cheap tyres for you!
