Paint/rust problem
Finished washing the car today and noticed a bit of rust about the wheel arch :(
Can someone advise the best way to deal with this, i assume it's going to be a costly process!
I'll upload a pic soon
Cheers, Chris
  • Views 935
without sounding offensive, try going to a bodyshop and getting a quote or asking for some advice from them rather than asking people on a forum,
theres always someone asking for advice about bodywork and 9times out of 10 all youl get is a load of crap that people have got fro google or heard off a friend, I'm in the trade and no advice other than going to a bodyshop will be of any help to you, please not that rust can be costly if it needs to be cut out but as i said, get it to a bodyshop and see what route they want to take, shop around for prices but try see examples of there work and ask around for a place with a good rep
As above, go a few bodyshops and get some prices, if they are all outta your budget there are ways to DIY arch rust buy depending on how bad it is it won't be pretty.
As both said above ^^
But being a 9n I'd imagine it's probably rusting because of exposed metal, if the paint has bubbled, it may be worthwhile to do as above
But if it's not bubbling under paint, you could just sand off the rust that you can see and then do a little patch repair (mask off area and spray) but obviously if it looks more like its worked it way through the metal (flakes of rust fall of by rubbing hand on it etc..) then I wouldn't attempt to repair it, take it to a body shop
It would probably be best to upload a picture and I'm sure someone on here will give you advice on the best/cheapest solution
Liam
Appreciate the replies!.. Just thought it'd check if anyone know common ways to fix it but body shop seems best/safest way to do to!
I'll upload a wee picture tomorrow so you can see what it's like
Thanks again :)
