Bodywork detailing...?
Can anyone post what products they use to wash their cars, how the products are meant to be used etc...?
I was my car normally, shampoo and polish, but i see alot of peeps using all kinds of products and dont know what they are XD
Thanks.
  • Replies 13
  • Views 1.6k
There's a sticky topic about this
Straight foward soap and water will do the trick.
You can buy a hand brush with a hose pipe attachment where you brush while water is sprayed out from the bush.
Ebay it. car water brush. buy one for alloys and one for the body work.
I wouldn't use a brush attached to your hose! If your car is dirty then it will pick up the dirt and with the dragging motion on your paint it will scratch it like mad. I had my car detailed and i can say I have learnt a lot.
Snow foam, Two buckets, Grit guard, Microfibre drying towels instead of shammy's, autoglym wheel acid (if you are car wheels aren't polished if they are, water and a sponge), Decent polish - Recommend the poor boys polish, Decent sealant and wax, Dodo Jucie for wax, Poor boys or Chemical guys for sealant.
Or you could autoglym your car like mad, Cost you alot more tho. Poor boys offer a better finish in my opinion to autoglym and a bit better for prices.
All of the products above wont be able to buy in shops like Halfords or car shops, Only detailer shops or on-line.
Have a look on here for the products.
My car before/After!
Before - Notice on the rear quarter all scratches and paint pitted.
After - Deep shine to the paint.
Hope this helped
Liam
Snow foam,
Clay bar,
That spray that's a decontaminant I can't remember
Wash again (two bucket & grit guards)
Paint correction with compound
Polish with a softer polish
Sealant
Wax
Love <3
Thats good thanks :)
Two more questions aha. First, what is that shampoo stuff that covers the whole car in a foam?
And what is a good product to use on wheels to get them spotless and then to keep them like that?
Liam your car came up amazing!!
Mr Blobby - Its snowfoam, and i just use shampoo and a sponge on mine :s lol
It's like polishing paint before removing contaminants, you'll get a much better finish cleaning the paint first!
Anything that cleans well with minimal effort probably damages, like acidic alloy cleaners arnt good over a prolonged time
Hi...
I use Autoglym mainly. Lambs wool mits and mircofibre cloths. this is a personal preference but I have two colours of mircofbres (outside and inside)
First things first.... Clay your car after a normal wash. the sticky clay with remove all dirt a normal wash fails to remove. I recently clayed my car with medium clay but next time will buy a soft clay. Then I T-cutted my car (sigh... my dads idea due to my car being red parts were fading) then used super resin polish and the HD waxed the car. The clay and wax only need doing every couple of months
I like snow foam but have not used it yet as I am researching the best types (any advice is very welcome). I use a lamb wool mit for body work and normal sponge for wheels as well as wheel care sprays (from my autoglym vallet kit). I have two buckets and different brushes for wheels arches etc... never use brushes on paint work. If I drop the mit or cloths on the floor I will not use it until it has been cleaned due to grit on my body work (BAD idea as creates scratches)
I am in the middle of buying a DA polisher to remove all scratches on my body work as although its looking rather fine at present I can see scratches made by previous numpty owner
Edited by ClaireBear
I wouldnt recommend autoglym as most of their stuff contains chaulk.
If u use polishes/waxes that turn your black plastic white, it more than likely has chaulk in it as a compound. not good!
I was a valeter for land rover and after using various products i cant fault 3m stuff!
Follow this with a good carnauba wax applied by hand and u have excellent results.
My valeting process would be
soak car and wheels with warm water
tfr wheels and body, soak for 5mins
Can do engine bay with tfr at this point aswell
jet wash car down and engine bay
car shampoo car and wheels
jet wash down
acid or clean wheels with your choice of cleaner
jet wash wheels
dry with chamois
apply 3m fast cut (green top) compound polish using a DA wetting panels as you go with cold water
jetwash whole car
chamois
apply 3m yellow top with DA (use this without wetting panels)
Buff car with a buffing cloth
apply a good carnauba wax by hand
buff whole car with buffing cloth.
....i havnt included windows or interior or dressing tyres or engine bay in this guide but i can assure you after this your paint will DEFINATELY look better than when it left the factory.
To do all this and finish the rest of the car your looking at a good 6hrs work!!
But after doing all this it helps make washing the car in the following 2/3 months ALOT easier if washed once a week.
Thats my pennies worth anyway lol :)
jet wash down
jet wash wheels
dry with chamois
jetwash whole car
chamois
Hi there... what products do you suggest please. I've never had a problem with autoglym to be honest but then I tape up my plastics which may be why its never happened to me
jet wash down
jet wash wheels
dry with chamois
jetwash whole car
chamois
Products i use are
tfr - auto smart, xl
wheel cleaner - auto smart, clean wheels.... i think its called
Car shampoo - 3m, car wash soap
compound polish with DA - 3m, fast cut (green top) this will flatten paint lovely, use 2000 wet and dry on any bad scratches before using this (wet sand)
Polish with DA - 3m, yellow top
carnauba wax - 3m, final finish.... i think its called
buffing cloths - meguiers buffing cloths
hope this helps
dan.
:lol::lol: I do hope your taking the piss.
It depends what you wanna do.
Detailling and paint correction massively depends on the state of the paintwork, what type of paint it is and how hard it is. For example, Alfa's paint is soft as fuck, whereas my polo is hard and you can hit it hard with a mop and its pretty forgiving.
The Meguiars microfibre system for a DA is good stuff.
Getting the paint clean before any correction is key.
Some sealants are AMAZING but the paint needs to be as good as it can be before applying it, some actually bond into the surface of the paint.
