Door seals, can they still be bought?
As the title says, can door seals for a mk2f Polo Coupe still be bought new? And if so, where from?
If not, anybody got any good condition ones they can sell me? :-)
Thanks in advance
Owen
  • Views 1k
Anybody?
I've been unable to get any new from a dealer thus far.
You can try the breaking section and see if you get lucky with one or just get a universal one, they should fit fine size depending of course.
Try here, I've not ordered seals myself but they will send a few samples and usually next day to test fit.
http://www.woolies-trim.co.uk/c-37-side-seals.aspx
Cheers for the link! I'll try my luck with their stuff. :-)
yes you can. VW Heritage can get them from VWclassic.de :)
Cheers for the reply! £50+ each is a bit more expensive than I was thinking though :retard: think I'll just try my luck with the universal stuff posted above
the trick is using a passenger side seal- these are less worn then the drivers- they are the same size and just require a little heat to reform the bends the other way
