Wind Deflector Modification
Please see pictures attached.
http://autospeed.com/cms/A_2456/article.html
The above report showed a gain of 5MPG which is quite a bit.
I'm going to get a undertray from scrap yard and cut out a middle section so my 4-2-1 manifold still gets sufficient cooling.
Have a look at the picture showing my wheel and the 16v bumper.
Is it not so easy place to mount some D.I.Y air dams :) I mean all you would have to do is literually screw them into the plastic housing arch and the shape is already done for you as the housing itself is of a CURVED nature.
The positioning of the deflector would be quite close to the wheel and there would not much area behind the deflector so you should not in theory get any "lift".
I noticed on the Blue motions that the deflectors do not cover the WHOLE of the wheel. They seem to cover two/thirds of the wheel. Wonder why that is?
Edited by damunk
  • Views 912
So what you want to do is put a bit of plastic in front of your wheels to deflect some air down the line of your tyres, building the under tray is pretty easy, sheet of plastic cut to fit.
Mk2f bumpers seem to flick downwards a bit in front of the wheels.
I am going to buy some coilovers and lower the car down by 30-40mm which will help aswell but formulas and reports over the internet say by reducing the drag by 0.01 CDA is equivliant to 100kg.
That is huge. I mean I had a debate over light weight allows a month ago and I bought some and it reduced the 0-60 by a further 6 tenths off a second. That is big! They were over 2kg lighter on each wheel.
By having a good air flow underneath the car will do the same! for what. Just some cheap ABS plastics.
But I know it has to be done right. That's why I thought I'd make a post here to begin with.
I might be wrong in what I'm saying. But I'm thinking that this will deflect the air away from hitting direct impact on tyres.
Going to lower the car by 30mm also.
Edited by damunk
