Budget coilies good or bad?
Ap are good for the money but is personally try put a little more to em and get some weitecs.
No one has complaints of the weitecs?
  • Replies 54
  • Views 4.1k
Depends what you're after. If you just want low and a fun drive then go for it. If you want any sort of ride quality or compliance to the road, spend more money.
If "decking" it id personally just get budgets as the amount of damper travel you'll have on whatever you fit will be almost zero.
Well those aren't exactly budget aha :) so what's the verdict? JOM OR TA-technik?
Jom
Okay cheers buddy :) do you know where you can get them cheap :) also would you buy coilies 2nd hand :)
Wouldn't buy cheap ones second hand personally.
I wouldnt buy cheap again tbh
Lol this thread seems to be going round in circles :D
Mine is a 16V which comes already slightly lowered.
I only want to lower it a further 20-30mm
What's best option for that. Springs or cheap/Expensive coilovers.
Each car is diff......
you have to sit in the same model of car with the said suspension to know....
I'm happy with my TA's with the bottom mounting flipped and raised. but each to.....
For E.G. Mk3 golf on KW V1's bouncy compared to my custom set....
Saying that though I'm talking bout stupid 120mm etc.... Drops. if its 20-50mm its great!!! even for £150...
Good quality lowering springs (STRONGLY recommend eibach) on good condition OEM dampers
X2 If you don't want an adjustable ride height.....
Listen to Mr Nicky Boy Racer ;)
Suspension Tech.... For a Panther Company... :lol:
I'm not on commission, but as far S quality goes eibach and bilstein are the bollocks.
The issue with your VW polo is I doubt any company has spent a length of time developing and tuning a kit, probably just spring calculations from vehicle weight and wheel to damper travel ratios and such.
But yeah, I'm not sure if the OEM setup uses the "bumpstops" as a spring aid or just for large compressive periods, as some cars have minimal bump clearance and use the spring aid as part of the whole setup, altering the bump clearance by 40mm may have an adverse effect,
I Still like the idea of carbs.......
Funding for the Fox???? :unibrow:
@harris.racing
If I went for springs would I be able to get 20mm if I just wanted to lower it by 2cm.
Smallest I've seen are 30mm springs on ebay.
Mm not sure, they probably only really make them 30mm ones you can find, but thats probably from the usual 6n height, which would equate to 20mm on your already 10mm lower valver? :)
Could do all the maths and get some custom springs made by Faulkner if can't find what you want.
That's tricky. I would be assuming the 16v is already lowered by only 1cm. I will have to do some research on the net.
Edited by damunk
It all sounds expensive tbh lol just looking for cheap coilies with about 100mm drop lol :) a's anybody got fk ones? I have seen that they are on offer ATM for £156 :) recommendations? Cheers guys it's my birthday today so looking to get a set asap lol :) a's long a's there not worse than my springs :)
HAPPY BIRTHDAYYYY
I've got some racelands and i love them, think the ride is awesome! I drive brand new toyota's all day and I'm actually happy to be driving my slammed polo on racelands cos 1. I can actually feel the road and 2. when i hit a bump the car doesnt bounce around after I've hit it, its just over and done with straight away. I can understand that spending £700+ on coilovers probably makes the car incredibly comfy and handle amazing, but at the end of the day, i dont have £700 to spend, so i bought some racelands and a year and a half after fitting them I'm still smiling :) hope that helps!
I bought some second hand racelands off and a guy on here and I love them too!
Completely agree with this guy ^^^ for the price £100 they are great, not overly hard and I've taken my nan out in the car (down 100 ish mm) and even she agreed they are pretty comfy, wouldn't say they are any stiffer than the standard set up on my dad's 54 plate fiesta, they stop that ridiculous body roll.
I've done a few long trips with them and cant fault them, BUT, I had them wound all the way up to -20mm and they were the most uncomfortable thing ever, even on a newly re-surfaced road I spent more time off the seat than on it, lasted 2 mins before I wound them back down. They were so hard I got an advisory on the MOT (reduced suspension travel IIRC)
I'm yet to have a problem with them after 4k miles and I smash them about a fair bit.
Where can you get them quite cheap from? I saw that you can get fk coilover kits cheap bit the drop on the cheap one is up to 70mm and it's not nearly low enough lol :) thankyou Harris.racing :)
Anyone know if weitec's gt for the Polo 6N weigh lighter or heavier than standard suspension please?
This thread :lol: :lol: :lol:
aids
standard ride height aids.
