mk2 polo inlet manifold for carburettor
mk2 polo inlet manifold that runs on a carburettor, i need this asap! like tomorrow asap! pm me or text me with location and price
07783877352
taa
cam
  • Replies 31
  • Views 1.6k
Solex carb and manifold off a 1982 GL 1043cc.
Where in S.Yorkshire are you?
if its one for a carbrettor model (mk2 engine not mk2f) then i have a few dude. no brake servo ect
barnsley, how much u want for it without the carb?
any pics? wer u located?
I have one for a pierburg carb, 1.3 engine of kerrly's is no good.
Also have one from an early mechanical head. It has the exhaust recirculation ports also
have u got pics of them please, that would realy help?
Not on me. What engine do you have? or do you know the carb you have?
got a few, al just need a clean up.
i think its a dmlr 32/34, on a MH head - i need the inlet port on to the carb to be long, like 2 holes joined together, if that makes sense?
yer thats the one i need, wer u located?
london, near watford
lol I'm in south yorkshire and i could do with this tomorrow! any ideas?
no a clue unless you can get here :lol: how comes you need one? whats up with yours?
i havnt got 1 thats y i need one, u think u could post it first class, tmro, so it would get here for friday? how much u want for it?
oh right lol, I'm at work tomorrow dooood, no time! sorry :/
I can post you one tomorrow boss. 1st class postage could be pricey though. Over a £10er for sure.
is the same as the one in the picture above? how much u want for it?
Don't worry about mine. I was seeing if you lived in Doncaster as I'm sat in the drivers lounge at the tesco distribution centre right now. A plan could have worked so well.
I'll whip it off a little later and let you know. IIRC they are all the same, and its the rubber hasket thats different.
£25 posted, as its going to cost the best part of £15 for delivery
nice one, if its the same ill have it, have u got the rubber gasket aswel?, give me a text becos i wont be able to get on here all day, 07783877352
i could have easily come over to doncaster for it! is the inlet manifold the correct one i need? with the large hole that connects to the carb?
I think u should give us some more info before u end up with the wrong one, isit for a 1.3 or a 1.0
Also isit an early engine (8 bolt cam cover) or a later engine with 3 bolts? As there is a slight difference.
Also id strongly suggest getting a new gasket, GSF do them its listed as a carbrettor flange, well worth the £20
Edited by erixtar1992
its on a 1.3 MH head, with a dmtl 32/34 carb, cam cover is 3 bolts, all it needs to be is a large 2 hole joined port were it attaches to the carb
I Gecha, the one i posted a picture of is for an earlier engine, as u can see it has a coolant hose for thr autochoke coming off the side of it, the nlater ones have a different hose setup, either can work if u have the right hoses, as i have a later one on mine as its neater.
