mk2 golf 1.6 cylinder compression
i know its not exactly polo but does any one know the compression in the i was getting readings of around 150 psi (10ish bar) on all four cylinders is that about right??
  • Views 1.4k
Autodata says 9~12 Bar 130~174 psi so you are looking OK :-)
Nige, sorry to ask.. can you find out what compression a g40 (PY) should be reading?
Thanks chap :thumbsup:
Edited by Matt G40
Autodata says 8~12 Bar 116~174 psi
cheers for that nige still leaves me with a emmissions failing lumpy running golf :x bloody brothers!!
legend, thanks mate :D
