wheel arch trim , bumpers need tlc ?
Ok its more the wheels arch trims on my 91 gt coupe than the bumpers thay need tlc as looking more grey than black so much shit on the shelf at halfords just not sure what to buy would like to know what you lot use and results you have had . many thanks
  • Replies 20
  • Views 1.3k
If they are really bad a heat gun works wonders but I use halfords own back to black stuff can't remember the exact name but it's in an all black spray can with a black lid, after trying numerous others I found it pretty damn good,
People will recommend linseed oil etc etc but I havnt tried those so I can't comment
Usually something thats meant for blackening tyres as it lasts longer. had some white shite in a green bottle (name escapes me!) which was bloody wicked. smelt nice too.
Megs tire gel works well.
heatgun is the best ( i use a not very powerful blowtorch :lol: ) just messes them up after a while apparently. I've done mine a few times though and there going strong!
id use a heatgun to bring them back up to black, and then just go over them every couple months with some sorta oil or something
Avoid the CarPlan back to black stuff, it gets EVERYWHERE and doesn't clean off easily. Spent ages masking off the paintwork and it still managed to make a mess!
Like others have said I think a heatgun is meant to be good if you are carefull with it and avoid long blasts.
Also heard good things about the AutoGlym bumper stuff.
I used wd40 when i had nothing else in add a few layers and run in worked pretty well, but as above back to black or tyre shine work the best IMO
i found the carplan back to black works great
done mine 8-9 months ago and its still looking great no fade at all
Thanks people :biggrin:
Gtechniq C4. Not sure there's anything that does the job as good. Colleague of mine reviews car detailing products and has not found anything that does the job like this does!
At 30 pound a go it needs to be the best lol
This, it's just expensive.
Heat gun basically brings the oil back up to the surface of the plastic, but that gtechnic stuff looks factory and lasts agesssss
Exactly, well worth the cash.
Check out the results here....
http://www.cleanyourcar.co.uk/forum/viewtopic.php?t=11172
Larger initial cost but at least you don't have to keep buying not so good stuff :) I'm getting myself some of that for when I clean the mk3 up.
I live opposit a detailed and he used the c4 on an old range rover (trim on them goes SHIT) and a year later it still looks factory! D
Its brilliant, i was dubious about it, thought it was a high cost branded item that did the same as the rest but after seeing the results and how long it lasts (up to a year later still looking pretty much factory) and how well it does those very hard to remove white bits i dont think id use anything else.
If only it would work to repair my satin paint work!
Shame this forum doesn't have a detailing section for all these tips and tricks and recommendations.
I found vinyl satin black spray paint worked better..
Been a few years now, not looking brand spanking new lately though, might be time for another coat.
Obviously paint works fine. Ha.
I use Autosmart highstyle and that seems to do the job :thumbsup:
Never ever thought i would get this much feed back but many thanks all for your help :biggrin:
Well we all like to help sometimes, anyone fancy coming to help do my new top mounts next ha! Oh and replay my worn paint job. Be most grateful ha
dude if you were not so far i would be up for it :biggrin:
